1 Gearbox no 2nd gear Mon Apr 19, 2021 12:05 am
dallasf
Howdy all,
Slowly rebuilding my 1989 k100RS. While it has been slow I finally got it running with new tyres and major service items and was preparing for my roadworthy certificate.
Took the bike out for a spin, 1st gear all went well, 2nd gear nothing, lunchbox gear selector went blank > couldn't even get to third.
The gearbox was the only fluid I hadn't changed, was an oversight on my behalf. Since the bike was neglected I pulled all the oil and it came up very silverish/dark, which from what I have read can be ok, but isn't great. The oil didn't feel metallic but the drain plug was full of gunk and felt slightly metallic.
I replaced the oil and gave it another run, this time i could get into second but it just rev'd like it was in neutral, I made it to third and could ride around. Obviously, this is not ideal. I have read many forums and it seems like this is a pretty common issue, with the result being a replacement gearbox?
If the end result is a replacement gearbox it would have to be from a wrecker. However, in my mind there is no guarantee that gearbox works or isn't about to die. I hear its a 7-hour ordeal to remove.
What do others do here? Rebuild with the following parts? - https://www.munichmotorcycles.com.au/product/gearbox-overhaul-kit-2/
Is a gearbox rebuild complex for a non-mechanic?
Looking for some advice, much appreciated.
1989 k100 RS SE - 168,000kms
