1 K100RS '84 Stalling when hot *resolved* Wed May 12, 2021 9:41 am
Djsfh
Hi!
I know, I know. One more topic with same problem. I have seen them all, but haven't had luck fixing the problem in the last month. Problem might lie there, as I am not competent with electronics, but trying my best.
One morning bike stalled after few minutes of riding when I was stopped, no problem, started back right away. At the afternoon I was riding 80km/h when bike suddenly stopped. Started to fire her up and worked ok for a short while and stalled again. Situation is the same now, works ok for 5-10min (even thought little rich I think) to a point that it stalls right away, no hiccups, just stalls. After stalling need to cool down and then starts ok again. I was very sure it was HALL-sensor and changed it, but no luck.
Here is a link to video with stalling:
https://drive.google.com/file/d/1V4ERUBVMhtCjWiclf4ll9fxi_Nk3jwI4/view?usp=sharing
I have used Bert's troubleshooting guide and values there.
Things I have done now:
I rode bike around 200km after keeping her in warehouse for winter, worked fine before all this.
What am I missing?
Thanks on advance
- Fuel pressure from before injectors and after them: Ok, ~35psi.
- Fresh fuel changed.
- New fuel filter.
- New crank breather z-tube.
- All grounds checked & cleaned.
- Voltage regulator changed to new one.
- HALL -sensor : Chanced to new Q-tech sensor.
- EFI computer tested with another one, no effect.
- Plugs: Changed to new ones.
- Injectors : Changed seals. Right voltage to injestors.
- Coolant thermal plug: Metered from it's plug, giving right values.
- Rough engine when throttle position sensor off.
- Not able to find any leaks.
- Not able to found any broken wires.
- 5&6 fuses changed.
- Vacuum switch disconnected, no effect.
- Air flow meter readings:
PIN 7-5: 93,3
PIN 7-8: 350,7
PIN 8-5: 361,1
PIN 8-9: 191,5
What am I missing?
Thanks on advance
