1 K100 not starting, trying to work with the troubleshooting guide and have some questions Sun May 30, 2021 5:26 pm
eran_k
i'm trying to help a friend with a non starting 1990 K100.
the bike has been converted to a "Café racer" and some changes to electrics were made (not by me), however it did work for a little while, but always had difficulties starting, some time ago it's wouldn't start anymore.
i'm trying to work with the troubleshooting guide but have some basic questions first:
1. There are places in the guide that have Volts~ symbol - does this mean i need to setup the multimeter to AC volts? - i think its mostly on the ignition module and jetronic module plugs.
2. from what i could see so far it seems the injectors are not "Pulsing", i hear them "click" once when pushing the start button and the squirt a single dose of fuel (fuel pump can be heard working so i believe the relay and fuel pump are ok - pump is new)
3. there's a spark on all 4 plugs - does this indicate the hall sensor is ok?
4. looks like the injectors are getting a constant +12V on startup - again i understand the pulsing is on the negative side.
any additional advise will be greatly appreciated
Eran
Eran
