1 Rear shock upgrade and injector clean Sat Mar 02, 2019 6:49 am
tinyspuds
I have fitted a new Ramshox jobbie. The OEM was shot and (mostly because I can’t resist tinkering, but also because I thought it might produce more lateral stiffness) I went for the 1” shorter version. Inspection of the old shock shows a slight curvature of the piston rod, so upgrade was probably timely.
Initial impressions/impact:
I can throw my leg over the bike from the ground rather than the pegs!
The shock appears to be excellent quality and is a thing of beauty (thanks for the recommendation Dai).
The suppliers have been very professional - although I did pose a question last night so I’ll report on their post-sales performance next week.
I have been very pleased with the set up of the outfit since my initial remedial work, nothing unpredictable and one handed steering at 60 on good highways.
On rough roads however the sidecar dominated handling by its agressive reaction to less than smooth surfaces. I assumed this was down to chair tyre pressure and torsion bar shock preload issues, both of which I was experimenting with. However, even with the new rear shock set at almost zero preload the behaviour on rough roads is greatly improved.
I was concerned that reducing the rear height might adversely affect steering geometry. However, initial runs still at minimal preload, show no return of the nasty headshake I spent a lot of time tuning out.
One problem that I hoped the new shock might help with was the feeling that the bike leant out too far on the adverse camber (I had previously set the bike to zero lean out without much improvement). Unfortunately, this condition feels much worse. I can’t persuade myself that it has anything to do with a shorter shock, so today I will crank up the preload to max and see what that does.
TBH that deterioration seems so extreme that I’m wondering if I’ve screwed up a support setting during the shock change (I took advantage of the changeover to lube the final drive splines so the bike was jacked up for a couple of days putting increased pressure on the chair).
For those that helped out with my very noisy top end, which I have also been working on since my Snowdonia adventure, Olaf called it right as a faulty injector. I had the injectors cleaned and rebalanced by Injectortune (fantastic service and result (please moderate out if endorsement not allowed)). Power delivery is silky smooth now and the death rattle has completely disappeared.
Thanks as always for everyone’s help and support.
Stu
Stu
