roach374
roach374
It's me again! This time, looking at the wiring diagram, it seems as though all the injectors are just wired to the Jetronic in parallel to always go off at the same time, regardless of individual cylinder timing. Am I reading this correctly? Shouldn't the injectors be "Squirting" only on the intake stroke for each cylinder, rather than all the time? (I'm new to FI bikes, so not sure of myself here)
['93 K75] Fuel injector wiring question? Screen13
1993 K75 standard
Yep they all fire at the same time.
The engine heat in the intake passages vaporizes the fuel so it doesn't really matter when the injectors fire. The only important thing is that there is the right amount of fuel injected each cycle.
roach374
roach374
Thanks for the answers!
1993 K75 standard
