1Back to top Go down   K75 injector wiring  Empty K75 injector wiring Sat 18 Aug 2018, 05:35
edmundf
edmundf
Hi all,
I am hoping you might be able to answer this quick question. I have replaced most of the wiring on my K75 project. Where the plugs go on the injectors there is a random loose wire. It may have had a terminal on it?. I checked to see if there was contunity with ground or voltage. Nothing. Does anyone know where this wire connects to the bike?
Picture uploading seems disabled for me so here is a Google drive Link to the offending wire
https://drive.google.com/file/d/1rKujKu3HSsf2jr3zC5zcCXDJ2EkmnLX1/view?usp=drivesdk
2Back to top Go down   K75 injector wiring  Empty Re: K75 injector wiring Sat 18 Aug 2018, 05:57
Its a brown wire so it goes to ground. There is a 6mm threaded hole between 2-3 cyl injectors on the head (the lower mount for the fairing also uses it) look down just behind the fuel rail and use a 6M bolt about 10mm length and tightens to about 8ft/lb
3Back to top Go down   K75 injector wiring  Empty Re: K75 injector wiring Sat 18 Aug 2018, 06:02
edmundf
edmundf
H Rick,
Thanks for the quick reply!. I was not sure as I was not seeing contunity with anything.
