1 K100 RS 16V ECU Sat 27 Aug 2016, 19:49
hi to one and all just putting this up to get some first hand info on 16valve ecu's im putting together a k100 rs 16v motor into a 1988 frame and have got a k1100 rs g-box and paralever fd assembly and secured a k100 rs16v motor from halo for the project to replace a 8valve motor intended for it , i have secured the main wiring loom and the engine [injection] loom and the the ignition control unit for it [ all from a 1990/1991 k100 16v what im chasing is a ECU to suit the rest , garyK told me his bike is running one a bosch unit number # 0-261-200-250 with another number on the id label 1464417 , now i have been offered a ECU from a '92-'93 k1100 lt if it has the same bosch number - as the 16v will it be compatible with the 1000cc motor or will the " brains" be different and what is this last number in black lettering mean ??? im not real savvy on injection/ ecu stuff being a carby man from way back any information or the slim possibility a forum member might have one they might part with will be appreciated woodcutter
