1Back to top Go down   3 unknown connectors? Empty 3 unknown connectors? Fri Mar 12, 2021 2:34 pm
JiiPee63
JiiPee63
Hi there,
I am finally putting parts back on the frame and the bike starts to look like a bike Very Happy. Fairing (all parts of it)  are at the paint shop. Will get them back on May - perhaps. While installing electric parts and wiring harnesses, I found three connectors for which I could not find a mating piece. Can anyone tell me what these are for? The connectors are circled in the pictures.
Thanks in advance.
3 unknown connectors? Connec10
3 unknown connectors? Connec11
3 unknown connectors? K100rs10
1986 K100RS 0089906 (Red)
2008 HD Electra Glide Ultra Classic (pearl white&black)
Ex - 1984 K100RS (white), 1986 Suzuki GR650
2Back to top Go down   3 unknown connectors? Empty Wiring Fri Mar 12, 2021 6:14 pm
daveyson
daveyson
Can't see the wire colours, but I'll say the two pin connector is for heated hand grips (optional) the three pin, upper in the second pic, hazard lights (optional)  and the four pin to the ignition switch. They could be confirmed with a coloured wiring diagram.
Heated grips.  green/black
                          brown
Hazard.            yellow/violet
                         white/blue
                         brown
Ignition.            red
                         grey/blue
                         green
                         grey
Last edited by daveyson on Fri Mar 12, 2021 7:04 pm; edited 4 times in total (Reason for editing : OK, finally lined the columns up.)
 ~120,000 km
3Back to top Go down   3 unknown connectors? Empty Re: 3 unknown connectors? Fri Mar 12, 2021 6:43 pm
In the second photo, the lower switch probably is for the "choke" switch. Does the yellow "choke" light come on when you turn the "choke" on?
It would help a lot if you could take some photos that show the wire colors.
4Back to top Go down   3 unknown connectors? Empty Re: 3 unknown connectors? Fri Mar 12, 2021 7:50 pm
Heated grips is 3 wire on K1100. Had to replace switches on mine. Same one for K100.
Is there ABS on that K?
Under tank left side clutch switch? Location fits. But same connector for brake switch and choke switch.
5Back to top Go down   3 unknown connectors? Empty Plugs Fri Mar 12, 2021 8:17 pm
daveyson
daveyson
I'm a bit wondering if it's later model wiring (and Vin) with early model frame? Then again I was struggling just to get the columns lining up.
I think I see early model tank support brackets on the frame. On my early model (and late model and wiring diagrams) the heated grips has two pins. They are flat pins in a T arrangement as in the photo.  It has round pins for the choke switch which are a bit further down the loom.
 ~120,000 km
6Back to top Go down   3 unknown connectors? Empty Re: 3 unknown connectors? Fri Mar 12, 2021 8:24 pm
daveyson wrote:Can't see the wire colours . . .
Point-Seven-five wrote:It would help a lot if you could take some photos that show the wire colors . . .
What color are the wires to each of those connectors, JiiPee?    Laughing
7Back to top Go down   3 unknown connectors? Empty Plugs Fri Mar 12, 2021 8:59 pm
daveyson
daveyson
I think I can see the clutch plug above the red circle, and the sneaky little choke plug hiding under the hazard plug.
Mine has the brake plugs on the right side.
 ~120,000 km
8Back to top Go down   3 unknown connectors? Empty Re: 3 unknown connectors? Sat Mar 13, 2021 6:23 am
Yes to this ^^
Assuming K100 and not K1100: top to bottom
- additional instruments
- hazard switch
- heated grips
Colours as per Daveyson.
9Back to top Go down   3 unknown connectors? Empty Re: 3 unknown connectors? Sat Mar 13, 2021 11:03 am
JiiPee63
JiiPee63
Thank you for your valuable comments Very Happy
There is no ABS in my bike - museum quality Laughing . It seems that 2-pin (T-arrangement) and 3 pin connectors match with Daveyson's wire colouring.
Instead, the colors of the white flat connector wires are as follows:
- braun
- blue/gray
- yellow
- green/black (there are 2 g/b coloured wires in a same pin)
I am pretty sure, that I have connected every switch, sensors and so on that I have in my bike. Have I forgotten/lost something? Those two small connectors I do understand now, but I am a bit confused about the flat white connector. I took hundred pics during the dismantling, but - of course - no specific pics about that area. Embarassed
Any ideas?
10Back to top Go down   3 unknown connectors? Empty Plugs Sat Mar 13, 2021 11:14 am
daveyson
daveyson
Yep, like Dai mentions, its for additional instruments (optional) for example for a fuel level gauge connection.
 ~120,000 km
11Back to top Go down   3 unknown connectors? Empty Re: 3 unknown connectors? Sat Mar 13, 2021 11:32 am
JiiPee63
JiiPee63
Thank you all for your help Big thumb
