1 K75S Handlebar Dimension Measurement Comparison Wed Feb 24, 2021 10:48 pm
Time To Ride
I going to widen the handle bar on my K75S to make it more maneuverable at slow speeds and just pushing it around. At a smidgen over 500 lbs it is harder to deal with the the r1150GS and just shouldn't be, getting old here. There is quite a few threads on here about this but it's a little bit here/a little bit there. robmacks post was the gem that fixed it for me, all there and I know what I am going to do.
I am going to remove the 1" back/1" up risers and go with Flanders/ 5/6/ then trim the bar ends back 2" or so. With luck I may be able to keep the exiting cables. Does anybody see a downside to this.
Flanders BMW Handlebars by Flanders Bars (sideroadcycles.com)
Thanks robmack
robmack's post
The following was the results of my research to locate handlebars for my project bike:
Handlebar Measurements
All measurements are made in normal riding position.
Height or Rise: Total height measured in a level plane.
Pull Back: Vertical lines from the furthest forward to rear in a level plane.
Center Width: Straight flat section before the start of the bends.
Width: Total overall tip to tip width, no grips or bar end weights.
Height:
Early S ----2 3/4"
Late S -----2 3/4"
C -----------4 3/8"
RT & T -----5 3/4"
Flanders /5 /6 (B21) chrome ------- 4 1/2”
Flanders R90S (C20) chrome ------ 3”
Bikemaster LTD ------------------------ 4 3/4”
Emgo Euro 23-12563 -------------------2” <--- This is what was purchased. Similar to R90S (C20) bars
Total Pull Back:
Early S -----5 1/8"
Late S ------5 5/8"
C ------------6 1/8"
RT & T ----10 3/8"
Flanders /5 /6 (B21) chrome ------- 9 1/2”
Flanders R90S (C20) chrome ------ 4 3/4”
Bikemaster LTD ------------------------ 7 1/4”
Emgo Euro 23-12563 -----------------5 1/2”
Width:
Early S -----23"
Late S ------24"
C ------------25 3/4"
RT & T ------27"
Flanders /5 /6 (B21) chrome ------- 28 3/4”
Flanders R90S (C20) chrome ------ 25 1/4”
Bikemaster LTD ------------------------ 30”
Emgo Euro 23-12563 ----------------- 29 1/2”
Center:
Early S ------4 3/4"
Late S -------4 3/4"
C -------------5"
RT & T -------5"
Flanders R90S (C20) chrome ------ 4”
Emgo Euro 23-12563 ----------------- 4 3/4”
Diameter:
Bikemaster and Emgo bars are 7/8" OD (.867"measured 22.12mm)
Flanders and BMW bars are 22mm exactly
S bars are .695-.700" ID
C, RT, & T bars are .615-.622" ID
Thanks robmack
robmack's post
Height:
Early S ----2 3/4"
Late S -----2 3/4"
C -----------4 3/8"
RT & T -----5 3/4"
Total Pull Back:
Early S -----5 1/8"
Late S ------5 5/8"
RT & T ----10 3/8"
Width:
Early S -----23"
Late S ------24"
RT & T ------27"
Center:
C -------------5"
RT & T -------5"
Diameter:
1994 BMW K75S ABS
USA Bike 43,000 mi
