2 Re: Rookie Mistake 2 Wed Nov 18, 2020 4:02 pm
mritz
Just realized the image is not clear enough... we are looking from a top view and that cable is located on the left side.
3 Re: Rookie Mistake 2 Wed Nov 18, 2020 4:25 pm
Suzi Q
well green and black is 12v fused via F1, and brown is ground, so the 2 pin plug is a 12v power supply for something - maybe illumination for a gauge?
Dunno about the 3 pin connector - the wire colours aren't clear.
edit: item 66 on the OE wiring diagram shows a 2 pin connector for heated grips with those wire colours
edit2: if the other plug is grey with blue, brown, green with black, then it's shown in the OE wiring diagram as a connector for additional instruments.
4 Re: Rookie Mistake 2 Wed Nov 18, 2020 6:50 pm
mritz
Chris,chris846 wrote:well green and black is 12v fused via F1, and brown is ground, so the 2 pin plug is a 12v power supply for something - maybe illumination for a gauge?
So, at this point, my goal is just to turn the bike on.
I don't have heated grips.
and I don't need any additional instruments.
Im assuming I can leave then without any connection for now correct?
5 Re: Rookie Mistake 2 Wed Nov 18, 2020 6:53 pm
Suzi Q
So long as it's not too cold, yes
6 Re: Rookie Mistake 2 Wed Nov 18, 2020 7:22 pm
mritz
Chicago cold? Never...chris846 wrote:So long as it's not too cold, yes
I've got those heated gloves, vests and pants...even in Jan Im pretty toasty...love to see peoples faces at the traffic light.
7 Re: Rookie Mistake 2 Thu Nov 19, 2020 12:21 am
3-pin connector is probably 4-way flasher switch. This would be the case if the wire colours are Blue-White, Brown and Yellow-Violet. Trace the wires and see if wires terminate on Flasher module connector.
2-pin connector is possibly heated grips connector True if wires are Green-Black and Brown. See if power (green-black) terminates on Fuse 1.
Neither of these connectors will prevent the bike from starting.
8 Re: Rookie Mistake 2 Sat Nov 21, 2020 6:40 pm
I shall have to check but the three point connector could be for testing the ABS. However I am unsure whether you have an ABS model.
VIN number, year model, etc in your signature block make a huge difference when asking technical questions.
9 Re: Rookie Mistake 2 Sat Nov 21, 2020 8:14 pm
According to his profile, the OP claims to own a 1985 k100rt so no abs.
Similar topics
