1 BEP Speed Output - Minimal required connections to BEP Tue Oct 27, 2020 11:49 am
PaulM
Hi,
We are having a small issue with a bep 3.0.
To summarize:
We are rebuilding an early K100 with m-unit and are using the BEP 3.0 only for:
- Gear Neutral indicator ( is working )
- Speedo
The BEP is powered using pin 6: Zündungplus
Masse is provided using pin 13
Pin 22 (induktivgeber endantrieb) has the yellow wire coming from the speed sensor from the rear.
The masse from the speed sensor is connected to the general Masse/Ground.
The ACEwell Speedo its speed-cable(green) is connected to the BEP 3.0 Outpost: SPD.
Unfortunately, we don't get any result.
Does the BEP unit need certain mass or power connections to make the SPD function work ?
Thank you,
Kind regards,
Paul
To summarize:
- Speedo
Thank you,
Kind regards,
Paul
