1 Tire Sizes and Aspect Ratios Fri Oct 02, 2020 11:56 am
Shopping for new tires for my 4v RS. I like Shinkos for the price to value ratio. Trouble is, like most of todays tire manufacturers, they don't have a lot of tires in the sizes our old bikes wear.
I'm looking at the Shinko Podium radials which I've never used before. The price is right for giving them a try, but I can't get a rear in 160/60-18. The choices are for a 170/60 or a 150/60. I'm pretty sure the 170 will raise the rear of the bike about 8mm and rub the swingarm while the 150 will lower it by that amount AND make the speedometer read even more optimistically.
I'm thinking the 150/60 with a speedo recalibration is the way to go, so the question is: should I go for the 120/70 front that is spec'd for the bike or the 120/60 that will lower the front by an amount similar to the rear?
Would I be better off raising the fork tubes in the clamps to lower the front? Will the lower profile tire have an effect on cornering, especially in wet conditions? I've already resigned myself to the added effort to get the bike up on the centerstand.
I have wheel shims for the rear, so I could also shim out the 170/60 rear tire to clear the swing arm. Would moving the wheel further to the left side affect the handling?
