1 1992 K1100LT Centerstand Thu May 23, 2019 11:22 pm
I have stuck a K100 Damper Unit on the 1100 and dropped the trees down the forks by the same amount about 30mm.
Now It's a Hernia initiating experience lifting it onto the Centerstand. I have a worn out K75 stand with the bend legs that I have cut those bends off. I am now to V cut and weld on a plate to act as the base for each leg and put the tang back on so I can deploy it. But I am aware of a difference between the 1100 stand and the 100 or 75 stand. Which Leg needs to be moved out to ensure the stand will work on the 1100. I cant figure it out. Help Please.
The legs are now only 7 inches long so maybe they wont even reach the tyre but I need urging on or maybe reassurance that when I stick her up on the saw horses and pull the 1100 stand off the 75 one will fit on and not rub or cause concern anyplace under there.
