1 K1100 stopped, wont start Tue Sep 08, 2020 2:10 am
Rockman
Ive been fiddling with this 93 K1100 for a while, and yesterday finally got it going. Apart from the usual cloud of smoke and a spray of wasp nests from the muffler it settled down pretty quickly. I gave it a few revs then let it idle. After maybe 8-10 mins max it suddenly cut out.
Today I tried again, checked all the electrical connections etc. Still no go.
Some details
- The fuel pump runs when I first turn it on then stops. Normal I think. Plenty of fuel BTW.
- On the dash I have the oil pressure, charge and temperature lights.
Heres what I find a little odd. When I try to start it, all 3 warning lamps go out, but only the oil pressure and charge ones come back on when I stop cranking. I would have thought all 3 should come back on. This makes me think I have a dodgy temperature sensor. The question is, do the symptoms fit and if so how do I test it? Can I maybe bypass the sensor temporarily?
ANy suggestion welcome?
If not then I'll attack it methodically and check spark, injectors working etc etc.
Some details
