1Back to top Go down   RT screen fixings Empty RT screen fixings Fri Jun 26, 2020 1:12 pm
How is the screen on an RT fixed to the fairing? I'n assuming that it doesn't use metal bolts but I don't have anything in the big box of bits that came with Kostenlot to let me take a good guess.
2Back to top Go down   RT screen fixings Empty Re: RT screen fixings Fri Jun 26, 2020 1:55 pm
ill guess that you dont have the threaded speed clips that fit around the fairing surround  that take the 5mm bolts through the screen ?
if im reading this post correctly
i think ill have to take a pic ?
below
RT screen fixings 20200326
i have used 5 mm  x 25 mm stainless with a slightly bigger washer , to spread the load of tightening across the
um ...perspex ... for want of a better description
note  the 2 rear most fixing locations (nearest the rider ), wont accept the speed clips because of the thinness  of the fibreglass at that location , i just use a good sized washer at the lower end of the bolt , with some cushioning rubber  closest the the fairing as a buffer .  nylock nut at the bottom .
hope that helps ...
3Back to top Go down   RT screen fixings Empty Re: RT screen fixings Fri Jun 26, 2020 2:29 pm
The fixings on the nibs near the rider are 10mm bolts on the inside and longer screws on the outside.
4Back to top Go down   RT screen fixings Empty Re: RT screen fixings Fri Jun 26, 2020 4:27 pm
Thanks guys. Charlie confirmed my supposition regarding the spire nuts as the fairing did come with them attached minus the four rear. The question I should have asked was: what is used to spread the load through the lexan screen? I did what I should have done in the first place and scrabbled around in the garage roof for the two screens I have. One had the answer; there was a single solitary convex plastic washer stuck to the lexan. Yet another call to Motorworks coming up...
Just FYI: they don't show on RealOEM.
5Back to top Go down   RT screen fixings Empty Re: RT screen fixings Fri Jun 26, 2020 4:38 pm
46 63 1 453 997 x 8 is shown as a 'hollow washer' under the screws and then washer 46 63 1 455 994 x 4 under the screen but above the 'clip nut' in the front main 'screen attachments for an RT in RealOEM. I have found over the years that it takes a fair amount of 'interpreting' of ETK to locate the bits required. It's a bit of a hunt and peck method. In fact, BMWNA, Chrysler, Subaru, VW/Audi & etc., call parts people "Parts Interpreters" in their official training classes.
RealOem US K100RT Section 46
6Back to top Go down   RT screen fixings Empty Re: RT screen fixings Fri Jun 26, 2020 4:54 pm
Automotive speed shops and Ebay should have countersunk aluminium washers. They come in various sizes and colours. https://www.ebay.com.au/itm/1-1-4-ALUMINIUM-COUNTERSUNK-BODY-WASHERS-PANEL-FASTENERS-10-PK-Hotrod/131359937946?hash=item1e95a9959a:g:8GgAAOSw0vBUdA~y
7Back to top Go down   RT screen fixings Empty Re: RT screen fixings Fri Jun 26, 2020 7:52 pm
£2.00 a bloody screw and I need six of them!!!!!! (Motorworks).
FRA08632
Fits K1 (09/1988 - 08/1993), K1100LT (09/1991 - 08/1999), K1100RS (09/1992... Show All...
Associated BMW part: 46632308632 (46 63 2 308 632)
RT screen fixings T
RT screen fixings Magnify_large Larger Image
Please note
This screw is prefitted with an integral plastic washer.
8Back to top Go down   RT screen fixings Empty Re: RT screen fixings Fri Jun 26, 2020 10:29 pm
That'll be 12 quid, sir.   Sad
Crowd funding, perhaps?
9Back to top Go down   RT screen fixings Empty Re: RT screen fixings Sat Jun 27, 2020 5:52 am
Well, I had a trawl round ebay and found some lovely solid ally cup/countersunk washers. BUT! By the time I'd added protective nylon washers for underneath and a set of countersunk screws, Motorworks were beginning to look decidedly cheap.
Quote TWB: 'Whoda thunk it.'
