1Back to top Go down   Tire size question Empty Tire size question Tue Jun 16, 2020 7:46 am
yamaguzzi
yamaguzzi
Is there any advantage or disadvantage  to mounting a 130 /80 /17 on the rear of a K100rs as opposed to mounting a 130/90/17 on it ?
2Back to top Go down   Tire size question Empty Re: Tire size question Tue Jun 16, 2020 9:32 am
yamaguzzi wrote:Is there any advantage or disadvantage  to mounting a 130 /80 /17 on the rear of a K100rs as opposed to mounting a 130/90/17 on it ?
If you're comparing bias-belted tires, an 80 on the rear will stiffen the ride.
3Back to top Go down   Tire size question Empty Re: Tire size question Tue Jun 16, 2020 9:36 am
yamaguzzi
yamaguzzi
Well, that is ok. You see,I run Avons and I can't get the 90 right now because of this damn covid crap.All the online tire places are sold out.I want to keep a matched set on the bike so I can get the 80 and do that.The front tire is still really good .They are a year and a couple months old so I only need a rear.I can live with a stiff ride .
4Back to top Go down   Tire size question Empty Re: Tire size question Tue Jun 16, 2020 10:30 am
yamaguzzi wrote:Well, that is ok. You see,I run Avons . . .
Which Avon?
5Back to top Go down   Tire size question Empty Re: Tire size question Tue Jun 16, 2020 10:49 am
yamaguzzi
yamaguzzi
Road rider
6Back to top Go down   Tire size question Empty Re: Tire size question Tue Jun 16, 2020 11:37 am
I took to 140/70/17 and very happy using that size, Battlax BT45.
On my K1100LT I have 160/60/18 on the RS wheel and also 140/70/17 on the LT wheel and find the turn in much better on the 140/70/17 LT set up.
7Back to top Go down   Tire size question Empty Re: Tire size question Tue Jun 16, 2020 8:21 pm
cycleman
cycleman
Going from a 90 series to an 80 series will affect gearing and your speedo. Smaller overall diameter. Other than that as long as they will both fit on the same rim dimensions it will work. Not sure if the smaller diameter would cause you any clearance issues on the bike.
8Back to top Go down   Tire size question Empty Re: Tire size question Wed Jun 17, 2020 7:30 am
Having run 130 and 140 profiles in 70 and 80 on my K100RT over 53,000 miles to be honest you are not going to notice the difference very much. The 70 does have a slightly lower speed rating in BT45 and not sure about the Avons but both are good for the K bikes.
9Back to top Go down   Tire size question Empty Re: Tire size question Wed Jun 17, 2020 10:05 am
cycleman
cycleman
A couple of other areas that it likely will impact is seat height and the effort required to get the bike on the center stand.
10Back to top Go down   Tire size question Empty Re: Tire size question Wed Jun 17, 2020 12:56 pm
BobT
BobT
13mm lower at the axle should make about 9mm lower seat. A pocket full of small change would make that much difference.  Very Happy
11Back to top Go down   Tire size question Empty Re: Tire size question Thu Jun 18, 2020 5:32 am
cycleman wrote:A couple of other areas that it likely will impact is seat height and the effort required to get the bike on the center stand.
I can vouch for that....
