1Back to top Go down   How to change a tire... Empty How to change a tire... Sun Feb 21, 2010 11:41 am
Here is what a friend posted. If you have never replaced a tire this is a good basic set of instructions.
replacing front tire
How to change a tire... Frog15How to change a tire... Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
2Back to top Go down   How to change a tire... Empty Re: How to change a tire... Sun Feb 21, 2010 5:29 pm
club_c
club_c
Hmmm, timely, I was going to take mine in. Maybe I'll try this first. Any hints about balancing a new tire?
3Back to top Go down   How to change a tire... Empty tyre changing Sun Feb 21, 2010 11:08 pm
Ajays
Ajays
Just ensure the tyre is in the correct rotation, there is an arrow on the side showing this.
The circular impression on the side should line up closest to the valvue.
I don't balance my tyres I only check them in the bike minus the calipers.
Mind you I do not ride at speeds much over 70/80 mph.
If you are a high speed man then get them balanced.
There is a kit to do this that I used with my car.It can be adapted to be used on a bike wheel if you have a lathe.
Finally, take a look on You-Tube there are a lot of methods there.
Suck it and see as Granny said.
Ajays.
https://www.youtube.com/results?search_query=motorcycle+tyre+balancing&search_type=&aq=f
https://www.youtube.com/results?search_query=motorcycle+tyre+fitting&search_type=&aq=f
