1Back to top Go down   Fuel rail cover from the K100 Empty Fuel rail cover from the K100 Tue Jun 09, 2020 4:41 am
AtLarge
AtLarge
Hello all, quick question.  Does anyone know if the fuel rail cover from the K100 will fit on a K1100?  The mounting holes are 152mm center to center on my RS.
1994 K1100RS
Color:  Grease
Mileage:  200,000+
Condition:  Used, well
2Back to top Go down   Fuel rail cover from the K100 Empty Re: Fuel rail cover from the K100 Tue Jun 09, 2020 4:37 pm
I can picture an aftermarket 'fuel rail cover' for K100 that, I think, CC Products sold. I don't know of one for K100 or K1100 from BMW as an OEM part. The rails are different part numbers for either model, but the mounting point centre to centre is the same between them - 152mm
3Back to top Go down   Fuel rail cover from the K100 Empty Re: Fuel rail cover from the K100 Tue Jun 09, 2020 9:28 pm
4Back to top Go down   Fuel rail cover from the K100 Empty Re: Fuel rail cover from the K100 Tue Jun 09, 2020 11:32 pm
AtLarge
AtLarge
Ah... Ok, my mistake then.  This is a picture I lifted off the web.  I thought it was an OE cover.  I did see that one on ebay just thought this looked a little cleaner.  Guess I'm on the hunt for the CC Products version.  Thanks for the help!
Fuel rail cover from the K100 NPNvHU1l
1994 K1100RS
Color:  Grease
Mileage:  200,000+
5Back to top Go down   Fuel rail cover from the K100 Empty Re: Fuel rail cover from the K100 Tue Jun 09, 2020 11:49 pm
A local sheet metal shop could probably fold one up out of stainless or aluminium pretty cheaply. Or with the aid of a vice and some strips of wood it wouldn't be hard to fold one up. Go on line and search  "How to fold sheet metal in a vice". You can then either polish it or paint it.
6Back to top Go down   Fuel rail cover from the K100 Empty Re: Fuel rail cover from the K100 Tue Jun 09, 2020 11:58 pm
AtLarge wrote: Guess I'm on the hunt for the CC Products version.
Here's where I bought a version of that cover. You could always lease its surface for advertising space to offset the cost. It's an unadorned basic molding but its holes aligned correctly. cheers
7Back to top Go down   Fuel rail cover from the K100 Empty Re: Fuel rail cover from the K100 Wed Jun 10, 2020 12:11 am
If you read Motorworks specs it states not suitable if RT/LT or RS fairing is fitted. You could always try and prove them wrong.
8Back to top Go down   Fuel rail cover from the K100 Empty Re: Fuel rail cover from the K100 Wed Jun 10, 2020 12:20 am
MartinW wrote:If you read Motorworks specs it states not suitable if RT/LT or RS fairing is fitted.
Well done. I hadn't noticed that or AtLarge's bike model. Adding a fancy-pants injector cover to an RS would be gilding the lily. Laughing
9Back to top Go down   Fuel rail cover from the K100 Empty Re: Fuel rail cover from the K100 Wed Jun 10, 2020 12:25 am
Laitch he has the option of going "Where no man has gone before". Cue Star Trek theme music.
10Back to top Go down   Fuel rail cover from the K100 Empty Re: Fuel rail cover from the K100 Wed Jun 10, 2020 1:00 am
Paint the cover red and it won't be any faster.
11Back to top Go down   Fuel rail cover from the K100 Empty Re: Fuel rail cover from the K100 Wed Jun 10, 2020 3:59 am
AtLarge
AtLarge
True however, my RS is naked. Only the front fairing is installed.  Wink
1994 K1100RS
Color:  Grease
Mileage:  200,000+
