Maenad
I've almost done converting my K100LT into a naked basic model having spent weeks and a lot of wages collecting the bits ! I have done the headlamp conversion no problem and went to what I thought was the easy bit:
I have the basic K100 radiator cover and the two small side panels which push into the grommets at the tank base. However even when they are screwed together there is nothing holding the radiator cover in place except these lugs popped into the grommets. Manuals show a diagram with a small mounting plate with rubber pad bolted to each side of the radiator which rest on the side panels. I could get these off motorworks but my radiator has no bolt holes at all in the sides to mount them. Is it a case of home manufacture to create a bracket of some sorts or have I missed something? Any advice is more than welcome.
Maenad
Send a post for help then went out to look again - solved it ! - the mounts are there but hidden by some plastic covers some previous owner had developed. At least posting the problem gave me a re-think. Cheers
Isn't it amazing how often you start posting and while typing the problem you actually come up with the answer.
One of my mentors said it always helps to go and talk to someone about the problem and more often than not you come up with the answer yourself, how true that is.
4Back to top Go down   K100 Naked - rad cover fitting - help and advice Empty Here Thu May 30, 2013 10:17 pm
ibjman
ibjman
Here, Here! Rick, I couldn't agree more.
I recently overwhelmed Charlie, with page after page of overly wordy rants & raves of questions about the technical working principals of the duel fuel light control circuit.....pages & pages of text. As it turns out, my description in detail of my curiosities did help me figure out the answers.
Maenad
Its very true - I spent two days with the bike in bits and a thousand frame parts coming off then couldn't see the obvious when I went to fit the radiator cover. At least I know the bike inside out now, cheers from UK guys.
jjefferies
jjefferies
Maenad wrote:I've almost done converting my K100LT into a naked basic model having spent weeks and a lot of wages collecting the bits ! I have done the headlamp conversion no problem and went to what I thought was the easy bit:
Could we see a photo of the finished project? I'm doing a similar thing with a K75C.
Maenad wrote:Its very true - I spent two days with the bike in bits and a thousand frame parts coming off then couldn't see the obvious when I went to fit the radiator cover. At least I know the bike inside out now, cheers from UK guys.
 Did you neatly lined up all the parts like this? lol!
K100 Naked - rad cover fitting - help and advice K-bike10
K100 Naked - rad cover fitting - help and advice Frog15K100 Naked - rad cover fitting - help and advice Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
Lazyboy
Lazyboy
Would love to get my hands on those parts !!!
1984 BMW K100RT
Bikes Name: Lazyboy
My LT got hit from behind so planning on making it naked too. I wont do much because even though it goes ok its got 101,000 miles on it and the exhaust studs are very corroded meaning a likely head off job if the exhaust has to come off for any reason. Not worth doing.
But I have now got an 84 K100RT same colour as the photo...Baja Red. Looks good in the flesh.
