1Back to top Go down   Fuel Injection - Setting Up Empty Fuel Injection - Setting Up Sun May 03, 2020 4:02 am
Bonzo
Bonzo
Howdy folks,
Like most people, I maintain/service my K100RS as it needs it. By this I mean the usual checks, fluid/filter changes etc. I've read of owners who say "I do all my own servicing apart from the fuel injection. That's best left to the dealer as they have the right equipment".
My 4v has done 58,000 miles, I've had it for just over 11 years and I've never had the FI looked at - and nor does my maintenance receipts show any record of it ever being done.
I cant say I can notice any problems with the way my bike runs apart from always needs a bit of choke on first start up (whatever time of year). Should I be looking at getting this 'checked over', or am I reading to much into it and maybe should just ride the thing?
2Back to top Go down   Fuel Injection - Setting Up Empty Re: Fuel Injection - Setting Up Sun May 03, 2020 4:34 am
volador
volador
Howdy,
You got the quarantine fever cause it certainly reads like it?
Unless you're planning on upgrading to the 4-hole fuel injector type, reading to much into it.
Ride on into the serene landscape...
3Back to top Go down   Fuel Injection - Setting Up Empty Re: Fuel Injection - Setting Up Sun May 03, 2020 4:39 am
Bonzo
Bonzo
volador wrote:You got the quarantine fever cause it certainly reads like it?
I think youre right volador.
Thanks for those words of reassurance mate. I hear you! Fuel Injection - Setting Up 112350
4Back to top Go down   Fuel Injection - Setting Up Empty Re: Fuel Injection - Setting Up Sun May 03, 2020 4:41 am
moriarti
moriarti
Hi Bonzo,provided,no leaks,good mpg,runs smooth,etc,leave well alone My local
GURU on all things K gave me this advise.As for the CHOKE my old beast  always needs it to start.So calm yourself and enjoy  Very Happy my mpg is 50/60 subject to RED
MIST riding  Twisted Evil Twisted Evil
5Back to top Go down   Fuel Injection - Setting Up Empty Re: Fuel Injection - Setting Up Sun May 03, 2020 4:54 am
Bonzo
Bonzo
moriarti wrote:Hi Bonzo,provided,no leaks,good mpg,runs smooth,etc,leave well alone My local
Aah, more reassurance. Love it  cheers
Cool mate. I wasn't sure if it was an 'interval' thing that I had neglected. Volador hit the nail on the head though. Too much sitting and reading Embarassed
The speedo reset knob you sent me is working great by the way  Fuel Injection - Setting Up 112350
6Back to top Go down   Fuel Injection - Setting Up Empty Re: Fuel Injection - Setting Up Sun May 03, 2020 5:36 am
If it ain't broke - DON'T fix it!!! Fuel Injection - Setting Up 44271
7Back to top Go down   Fuel Injection - Setting Up Empty Re: Fuel Injection - Setting Up Sun May 03, 2020 9:22 am
As long as you keep doing 5,000 miles per year, all you need is do is replace the fuel filter every other year and the fuel lines when they get hard.  The only thing that fuel injection really needs is to be used regularly so the fuel doesn't sit in the tank for more than a month.
The "choke" isn't a choke.  It's a throttle opening to provide a little more air/fuel mixture to help a cold engine to overcome the internal friction caused by cold oil.  Once the engine starts to run, the oil viscosity rapidly drops due to viscous shear so choke can be turned off.
8Back to top Go down   Fuel Injection - Setting Up Empty Re: Fuel Injection - Setting Up Mon May 04, 2020 5:17 am
Sounds like its running good.
As said, best left alone.
Don't go for the 4 hole injectors though, they run cleaner simply because they may be newer but they increase fuel consumption. If you do go at them make sure to have a 10 pack of O rings.
