1 Fuel Injection problem Mon 05 Jul 2010, 15:46
Hello all
I'm back with another seemingly stupi question.
My 85 RT has not been started for a few years and I have done all the suggested steps so far. I found that the spark plugs were all showing a good spark, but 3 of them were dry, the fourth was wet and dirty. The bike was sounding like it wanted to kick, with a small amount of black smoke exhausting.
So, following some of your good leads, (the easiest one s first, that was another good lead), I removed injector rail and carefully hit the starter.
Yep, 3 not working and the fourth cats hissing out. So I have removed the rail and taken it to an ultra sound bath. He asked me where were the ceramic caps off the ends of the injectors ( over the needle apparently) WHAT? was my idiots' response. He told me that there should be caps on the ends inside the engine, and maybe they have fallen off inside the injection holes. OR someone else has replaced the rail without putting them back on. The shop will replace the O rings and caps but it's up to me to figure out if they are stuck in the holes. OMG as they say. Anyone had any similar probs, with solutions that doesn't involve pulling major bits off . Please?.
Also found that the fuel that ran out when I removed the in line was full of crap. I had cleaned the tank, new pump/lines/filter. Hoping that the crud was in the fuel rail, but need to drain the tank. Is there an easy way to do that? I will look it up again but whilst I'm here thought someone could help again.
Thanks for the help, hope you northerners are enjoying summer, I have to find a German football flag now. Cheers.
