1Back to top Go down   High rpm then dies Empty High rpm then dies Thu Apr 02, 2020 11:28 am
PiotrK100
PiotrK100
Hi
From time to time some strange situation occurs and have no logical explanation so must turn to the weiser brains on this forum.
Here is the situation: (no matter engine hot or cold) when you rev for a moment like max rpm and than close throttle fully, when rpm drops it not stay on idling but chocking for moment and dies. This is flustration when you accelrate before crossing and must stop quickly. Thanj you stay on crossing with engine shut down.
Any idea where to dig for seolution?
http://www.xenum.pl
2Back to top Go down   High rpm then dies Empty Re: High rpm then dies Thu Apr 02, 2020 12:40 pm
I would look for an air leak in the Z-tube and around the throttle bodies.
It could also be a problem with the voltage regulator/brushes on the alternator causing a voltage drop that doesn't provide enough electrical power to keep the engine management systems running.  I had that problem with a 1992 K100RS 16V.  You may see a problem with keeping the battery charged.
I have a 1988 K100RS right now that needs a new regulator.  It doesn't charge the battery unless the rpm is above 3500.
3Back to top Go down   High rpm then dies Empty Re: High rpm then dies Thu Apr 02, 2020 1:28 pm
volador
volador
PiotrK100 wrote:Hi
This is flustration when we have to guess what moto year and model you own? Maybe good to update your profile
What have you recently done to it?
4Back to top Go down   High rpm then dies Empty Re: High rpm then dies Thu Apr 02, 2020 3:07 pm
PiotrK100
PiotrK100
volador wrote:
PiotrK100 wrote:Hi
Hi
Sorry for that, but last years I was dealing with more that few bricks. I just love that bikes, despite the fact I own also other bikes. Currently I m working on my friend bike from 1983 year, like the first from production, but the engine was changed for 1989 LT.
 Personaly doing on a new project, mine project, which is totally diferent from others. Generally I'm surrended ny bricks. Can not attach pictures on this forum...
http://www.xenum.pl
5Back to top Go down   High rpm then dies Empty Re: High rpm then dies Thu Apr 02, 2020 3:14 pm
PiotrK100
PiotrK100
But I have my own group where I do include all pictures from my projects, so if you want to look at that you must send me request. Group CUSTOMMANIA and the picture shows K100 drivetrain so easy to recon.
http://www.xenum.pl
6Back to top Go down   High rpm then dies Empty Re: High rpm then dies Thu Apr 02, 2020 3:51 pm
volador
volador
Fuel injectors?
Petrol tank fuel level/pump connector?
[url=http://www.kforum-tech.com/how-to/Modification for early gas tank.htm]Petrol tank return check valve?[/url]
Throttle position switch?
7Back to top Go down   High rpm then dies Empty Re: High rpm then dies Thu Apr 02, 2020 4:31 pm
Never hurts to (when the tank is low) pull out the fuel filter and try to blow through it to make sure that it's not restricting flow.
8Back to top Go down   High rpm then dies Empty Re: High rpm then dies Thu Apr 02, 2020 4:42 pm
PiotrK100
PiotrK100
duck wrote:Never hurts to (when the tank is low) pull out the fuel filter and try to blow through it to make sure that it's not restricting flow.
Installed new fuel filter today. No change
http://www.xenum.pl
9Back to top Go down   High rpm then dies Empty Re: High rpm then dies Thu Apr 02, 2020 9:16 pm
Clearance may be too tight on the exhaust valves or running lean.
10Back to top Go down   High rpm then dies Empty Dies Thu Apr 02, 2020 10:11 pm
daveyson
daveyson
Have you eliminated any causes so far? Sometimes just normal service items are the cause like spark plug gaps too wide, leads loose, something like that.
 ~120,000 km
11Back to top Go down   High rpm then dies Empty Re: High rpm then dies Fri Apr 03, 2020 12:28 am
volador
volador
clean and properly seat the LE-Jetronic ECU connector under the seat
many have encountered a loose or improperly seated connector
12Back to top Go down   High rpm then dies Empty Re: High rpm then dies Fri Apr 03, 2020 9:27 am
PiotrK100
PiotrK100
Valve clearance, done. ECU connection done. Ignition done, Spark plugs done, fuel pump and injectors done. Allmost all have been done already, so I'm a bit confused.
http://www.xenum.pl
13Back to top Go down   High rpm then dies Empty Re: High rpm then dies Fri Apr 03, 2020 11:07 am
Have you tried disconnecting the TPS? That might help.
(Throttle Position Switch - on the back of the throttle bodies.)
14Back to top Go down   High rpm then dies Empty Re: High rpm then dies Fri Apr 03, 2020 3:48 pm
PiotrK100
PiotrK100
Checked for air leak but....no that is not the reason.
But what I did is I adjust TBS and for now engine is idling droping from high rpm...will check tommorow after longer trip.
Anyway, THANKS to everyone for help!!!! cheers
http://www.xenum.pl
15Back to top Go down   High rpm then dies Empty Re: High rpm then dies Fri Apr 03, 2020 4:32 pm
volador
volador
you owe 2 case of Zywiec to Admins for ongoing support
