Number of posts : 4461
Contact Ring - Part 61121459998
Plug it in instead of the side stand switch at two wire (green/yellow and green/red) connector under the right side cover.
It's just a connector with an exposed loop of wire. You could cut that wire and put a switch in the circuit very easily.
There are two wires to the side stand switch:
Green/Yellow - Power from the kill switch on the right combo switch
Green/Red - Power to the 86 terminal of the fuel pump relay
