Number of posts : 7967
duck wrote:Yes.
You need a monolever swing arm, final drive and drive shaft. (And a different shock.) The swing arm and drive shaft will work with your existing transmission without modification.
You need to figure out what final drive gear ratio you want. 32:10 from a K75 or 33:11, 32:11, 31:11 from a K100.
If you are getting the Monolever final drive and the drive shaft from different places, make sure they are either both 16 spline or 20 spline as they are not interchangeable. Either will work with yours but they need to match each other. The 16 spline are on early Ks [K, K100RS and K100RT].....K100LT are all 20 spline.
I just had a quick look at my K100RS [monolever] and my K1100LT [Paralever] just check out the rear brake line from the caliper to the master cylinder. Mine are not same but the RS one was changed by the PO so not sure if the difference is due to him or BMW.
1971 Yamaha 125 YAS-1
