1Back to top Go down   Clutch cable rubber boot replacment Empty Clutch cable rubber boot replacment Fri Sep 20, 2019 3:51 am
audibob
audibob
I recently changed my clutch cable for a Venhill unit from Motorworks.
The bellows supplied seemed too small so I ordered the Motorworks rubber bellows,  item code CAA25866, and
 then had to find a way to get the boot over the cable barrel.
Using a small length of 13mm copper pipe clamped in my vice,  I used a small set of external  circlip pliers
to open the end of the bellows, and slide it onto the pipe.
This takes patience, but it will go on the pipe.
It will stretch to the point where you think  it will split, especially at the smaller opening , but it didnt.
I lubed the rest of the pipe to move the bellows to the end ,  slid the pipe with the  bellows over the cable
and barrel, ensuring the barrel is at the bottom of the cable and then pushed the bellows off the pipe.
Took me longer to fit the bellows than it did to swap the cable itself.
Hope this helps someone
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Triumph T 140V Bonneville
Triumph T150 Trident
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
K100 LT current bike
Did the same, but first heated the boot in hot water, and used siliconenspray to get the boot in place.
Clutch cable rubber boot replacment Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
I don't worry about that boot. It serves no useful purpose.
I suppose it may help keep the cable from getting wet and rusting but a light coat of grease will take care of that.
I think it's just there to make measuring that 75mm distance harder when you do a clutch adjustment.
