1Back to top Go down   Tyre valve dust cover Empty Tyre valve dust cover Fri Aug 23, 2019 5:46 am
tinyspuds
tinyspuds
Just discovered that they are a perfect fit for the threaded end of brake light switches. Nice tidy protection for spare switch.
2Back to top Go down   Tyre valve dust cover Empty Re: Tyre valve dust cover Fri Aug 23, 2019 7:05 am
Tyre valve dust cover 44271 You've got too much time on your hands. Get the bike out and scare the old ladies on Balham high street!
3Back to top Go down   Tyre valve dust cover Empty Re: Tyre valve dust cover Fri Aug 23, 2019 7:28 am
tinyspuds
tinyspuds
Dai wrote:Tyre valve dust cover 44271 You've got too much time on your hands. Get the bike out and scare the old ladies on Balham high street!
lol! Actually had a useful reason to find out that may be worth sharing. The rear brake light switch failed and was seized into the footplate socket. I drilled it out with 7.5mm but that left a brass residual   blocking the threads. Couldn’t find an 8mm bolt with the right pitch until I tried the dust cap and found it fitted the switch perfectly. Dremmeled a groove into an old valve and worked it through the hole to clean the threads. New switch installed without fuss.
4Back to top Go down   Tyre valve dust cover Empty Re: Tyre valve dust cover Tue Sep 03, 2019 12:44 pm
Now I can keep the air from leaking out of my switches. (Or smoke if they're Lucas switches.)
5Back to top Go down   Tyre valve dust cover Empty Re: Tyre valve dust cover Wed Sep 04, 2019 5:57 am
tinyspuds
tinyspuds
They’re a good fit. but nothing can stop the prince of darkness smoking.
