1Back to top Go down   K100 Centerstand Empty K100 Centerstand Wed Sep 22, 2010 1:25 pm
otto59
Purchased a used center/sidestand assembly from a 92 K75 to replace my cracked 85 unit. I heard that BMW improved them over the years and am wondering how to tell. The only difference between it and my old one is the 92 has a slight bend in the sidestand, mine is straight.
2Back to top Go down   K100 Centerstand Empty Re: K100 Centerstand Wed Sep 22, 2010 5:00 pm
The difference between the very early ones breaking and the newer style is the addition of a gusset on the new ones.
K100 Centerstand Frog15K100 Centerstand Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
3Back to top Go down   K100 Centerstand Empty Re: K100 Centerstand Wed Sep 22, 2010 5:35 pm
Ajays
Ajays
K100 Centerstand DSC00407
K100 Centerstand DSC00406
Centre stands are not supplied with new bikes today and to save humping I just ride straight into this.
This was home built but a lighter one is supplied at various outlets at around £65. UK supplier www.motorbikebits.co.uk
K100 Centerstand Th_Kengine_gif
AJAYS
4Back to top Go down   K100 Centerstand Empty Re: K100 Centerstand Wed Sep 22, 2010 7:14 pm
Ned
Ned
Ajays, I've been looking at one for my Goldwing... what do you think about a unit like that for a 300kg bike? Can it support the bike without the centre stand?
Ned
5Back to top Go down   K100 Centerstand Empty Re: K100 Centerstand Wed Sep 22, 2010 8:25 pm
phil_mars
I think the beauty of it is that it is not really carrying a lot of weight as you just roll in and out so it is only the weight of the front end and has much wider bracing than the standard centrestand so I suspect the only limitation is the width and size of the front tyre which on the commercial models is adjustable.
But if you are handy with a welder the picture speaks a thousand words.
Phil
6Back to top Go down   K100 Centerstand Empty Re: K100 Centerstand Wed Sep 22, 2010 9:14 pm
Ned, if you are looking at some sort of support for your Goldwing, can't you attach it to the front of a prawn trawler with chains...that way it can be raised and lowered when you need to use it... Twisted Evil
7Back to top Go down   K100 Centerstand Empty Re: K100 Centerstand Wed Sep 22, 2010 9:22 pm
Ned
Ned
Smile my only comment :
K100 Centerstand Oh%20I%20am%20sooo%20tired
Ned
8Back to top Go down   K100 Centerstand Empty Re: K100 Centerstand Thu Sep 23, 2010 2:15 am
Ajays
Ajays
Need I say more?
Quite easy to construct.
Ajays
9Back to top Go down   K100 Centerstand Empty Re: K100 Centerstand Thu Sep 23, 2010 6:20 am
Ned
Ned
Thanks Ajays. All my questions are answered Smile I only need one because the Wing doesn't have a centre stand at all. Because it was lowered by 2" the C. Stand use is not at all possible, so this would be my solution to keep the beast upright as I work on the left head at some stage.
Ned
10Back to top Go down   K100 Centerstand Empty Re: K100 Centerstand Thu Sep 23, 2010 1:07 pm
otto59
Where exactly should this gussett be attached?
11Back to top Go down   K100 Centerstand Empty Re: K100 Centerstand Sun Sep 26, 2010 12:20 pm
K Put
K Put
otto59 wrote:Purchased a used center/sidestand assembly from a 92 K75 to replace my cracked 85 unit. I heard that BMW improved them over the years and am wondering how to tell. The only difference between it and my old one is the 92 has a slight bend in the sidestand, mine is straight.
Hi. the best idea is to get a stand complete with mount from the K1100 series these had straight legs and were much better than the original. I have fitted one to both of my K100s. Be careful not to get duped with a k12 stand, the mount will fit, but the stand legs are too short. I believe they'll fit the K75 too.
HTH Garry
