1Back to top Go down   Centerstand Collapse 1985 K100 Empty Centerstand Collapse 1985 K100 Mon May 03, 2010 11:17 pm
sprocket
Ouch! Came home from a ride tonight and pulled in the garage and went to put unit on centerstand,over it fell into the work bench.
I caught it no major damage. I believe the stand broke in two. I will put it on lift in morning, perhaps a bolt broke.....I had read somewhere that after
years of use they went bad......(RUST INSIDE)
One thing after another, but on the good side it could have broke on a trip Centerstand Collapse 1985 K100 Icon_biggrin .....
So it wil get fixed tommorrrow..........................%#**t
I keep saying " I love this old beast"
Sprocket"
Ohio........................................................................................ Centerstand Collapse 1985 K100 Affraid
2Back to top Go down   Centerstand Collapse 1985 K100 Empty Re: Centerstand Collapse 1985 K100 Tue May 04, 2010 1:40 am
dee why
dee why
Sprocket, fitting the re designed K1100 centre stand is a good upgrade. I have one on my 87 K100.
Cheers,
dee why
3Back to top Go down   Centerstand Collapse 1985 K100 Empty Re: Centerstand Collapse 1985 K100 Tue May 04, 2010 1:53 am
Dee Why...any modifications or bolt right on?
thanks,
4Back to top Go down   Centerstand Collapse 1985 K100 Empty Re: Centerstand Collapse 1985 K100 Tue May 04, 2010 2:17 am
dee why
dee why
The stand was fitted by the previous owner (my BM mechanic), but I think a bolt on with perhaps a small trim of the left foot for tyre clearance. Can't see any obvious mods except grease nipples fitted.
5Back to top Go down   Centerstand Collapse 1985 K100 Empty Re: Centerstand Collapse 1985 K100 Tue May 04, 2010 2:31 am
dee why
dee why
See this previous thread:
http://k100rt.aforumfree.com/frame-fairing-and-wheels-f9/centre-stand-t709.htm
Not sure how to hyperlink yet.
Cheers,
dee why
6Back to top Go down   Centerstand Collapse 1985 K100 Empty Re: Centerstand Collapse 1985 K100 Tue May 04, 2010 5:19 am
Thanks dee why...how did I miss that thread!
Must have been asleep.
thanks,
7Back to top Go down   Centerstand Collapse 1985 K100 Empty Re: Centerstand Collapse 1985 K100 Tue May 04, 2010 6:32 am
Here is what you need
This one is quite cheap.
Centerstand Collapse 1985 K100 Frog15Centerstand Collapse 1985 K100 Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
8Back to top Go down   Centerstand Collapse 1985 K100 Empty Re: Centerstand Collapse 1985 K100 Tue May 04, 2010 12:14 pm
Bruce
Bruce
Do the grease nipples come standard from factory? I don't have any on my 86 RT, just a couple of holes, is that where you fit the grease nipples on the centrestand? Are all grease nipples a standard thread or are there fine and coarse threads? thanks B!
9Back to top Go down   Centerstand Collapse 1985 K100 Empty Re: Centerstand Collapse 1985 K100 Tue May 04, 2010 10:13 pm
dee why
dee why
Bruce, there are grease nipples on the K1100 stand in the photo in Phil's post. I'm not sure if standard or not, but would be cheap to add if required.
dee why
10Back to top Go down   Centerstand Collapse 1985 K100 Empty Re: Centerstand Collapse 1985 K100 Tue May 04, 2010 11:23 pm
phil_mars
Can't say much more other than they came with them but again secondhand to begin with but looked standard.
Phil
11Back to top Go down   Centerstand Collapse 1985 K100 Empty Re: Centerstand Collapse 1985 K100 Wed May 05, 2010 3:37 am
By 1990 they were fitting grease nipples.
12Back to top Go down   Centerstand Collapse 1985 K100 Empty Re: Centerstand Collapse 1985 K100 Wed May 05, 2010 4:57 pm
sprocket
Were good on centerstand.
Put Piece of Cold roll inside stand.
Made two Gussetts for curved part.
Test fit and did some minor grinding.
Primed and painted Good as new................
I guess it could have broken on trip...
Now I believe everything is Fixed( fingers crossed)...
Thats Life! INTERESTING! Centerstand Collapse 1985 K100 Icon_biggrin
Sprocket"
Fremont,Ohio........................................
