2 Re: Fuel tank leak Wed Aug 21, 2019 3:34 am
hi porto ,
many have experienced the same
if you can find a fabricator , that will work by welding a fuel tank , many wont look at it hands down , but there are some out there
usually a plate welded to cover the hole will work fine , BUT , be aware that up the side of the tank in the same area is another likely weak point , where oxidisation has thinned out the aluminium skin , as you have seen near the fuel pump . its a low point in the tank where water will sit and oxidise away un-noticed for years
whilst its apart ...probe in that area and get it done at the same time
good luck
good luck
3 Re: Fuel tank leak Wed Aug 21, 2019 4:13 am
Porto
Thanks Charlie,
That all makes sense now mate. I will start looking for a welder now. I was worried I would have to try and apoxi it up .
4 Re: Fuel tank leak Wed Aug 21, 2019 4:19 am
There a welder up here in Brisbane which did mine but that wont help unless your posting it up
I had 8 holes in mine and then he pressure tested it for me
1986 K100 RS Motorsport
1988 K100 RS SE
1990 K1 known as Barn Find
#### K100 RS Project
5 Re: Fuel tank leak Wed Aug 21, 2019 7:21 am
I agree with Charlie - go for a weld repair rather than epoxy.
I've had K bike tank leaks welded up in both Sydney & Maitland. Might be worth seeking out marine fabricators who work with aluminium all the time.
1990 K75 6427509; 1987 R80G/S PD 6292136; 2010 G650GS ZW13381;
6 Re: Fuel tank leak Tue Aug 27, 2019 5:04 am
Porto
Thanks for the advise fellas. I’ve filled it with an epoxy to hopefully keep me going till I find a welder near me. I’m hoping it seals it or at least plugs it so it’s just seaping a little. I can’t cope having it off the road. I’ll start checking marine places for tank welders.
Similar topics
