1Back to top Go down   Headstock bearing  Empty Headstock bearing Mon Aug 05, 2019 1:47 pm
dakelvinator
dakelvinator
Hi I have a 1992 K1100LT with 46k miles on the clock, I think the head stock bearing needs replacement or adjustment at least! Their is play in it and if i go over a bump or speed hump it sounds painful! It it possible to DIY? I have done clutch and splines to give an idea of my skill level Smile . Is this hardship to do? Thanks K.
2Back to top Go down   Headstock bearing  Empty Re: Headstock bearing Mon Aug 05, 2019 2:21 pm
Page 32.13 in the BMW shop manual.
You can download the manual here:
http://bit.ly/new2kbikes
3Back to top Go down   Headstock bearing  Empty Re: Headstock bearing Mon Aug 05, 2019 2:46 pm
dakelvinator
dakelvinator
duck wrote:Page 32.13 in the BMW shop manual.
Thanks Duck, some bed time reading! k.
4Back to top Go down   Headstock bearing  Empty Re: Headstock bearing Mon Aug 05, 2019 2:58 pm
walfish
walfish
Use 22 mm copper pipe as the spacer ring (item 3), the length I do not know, you can measure it, also suggest sitting on  the bike off the stand on tarmac and rock it back and forward with the front brake held on will indicate the extent of play.
Hope this helps. Headstock bearing  112350
Headstock bearing  Uk-log10
                            88 K 100  0033026 (gone)
                            92 K 1100 LT  6455097 (gone)
5Back to top Go down   Headstock bearing  Empty Re: Headstock bearing Mon Aug 05, 2019 3:35 pm
dakelvinator
dakelvinator
walfish wrote:Use 22 mm copper pipe as the spacer ring (item 3), the length I do not know, you can measure it, also suggest sitting on  the bike off the stand on tarmac and rock it back and forward with the front brake held on will indicate the extent of play.
Thanks - Yep defiantly got plenty of play in it!  Rolling Eyes
6Back to top Go down   Headstock bearing  Empty Re: Headstock bearing Mon Aug 05, 2019 5:09 pm
mike d
If the head bearings have been slack for any length of time, the constant pounding can/will cause brinelling of the bearing cup. This can lead to the bars almost self centring. This can be felt as a slight reluctance to minor handlebar movements about the centre when slow speed riding (e.g. filtering), which can be disturbing.
Mike
7Back to top Go down   Headstock bearing  Empty Re: Headstock bearing Mon Aug 05, 2019 6:08 pm
You can also detect if the steering head bearings are "notched" in the center if you jack up the front end and turn the handlebars from side to side.
8Back to top Go down   Headstock bearing  Empty Re: Headstock bearing Tue Aug 06, 2019 10:19 pm
dakelvinator
dakelvinator
mike d wrote:If the head bearings have been slack for any length of time, the constant pounding can/will cause brinelling of the bearing cup. This can lead to the bars almost self centring. This can be felt as a slight reluctance to minor handlebar movements about the centre when slow speed riding (e.g. filtering), which can be disturbing.
Mike
Thankfully its not this bad yet i am hoping to get away with just an adjustment scratch k.
