1Back to top Go down   1985 K100 drive shaft/U-Joint Empty 1985 K100 drive shaft/U-Joint Thu Jun 28, 2012 1:24 pm
rwiley111
rwiley111
I see this question asked but do not see the bearing number or spec/mearsurements published. I pulled the drive shaft to check and grease the Splines and found that the U-Joint is about to go. Looked up new OEM drive shaft at MAX's and currently $429.90 plus shipping and changing with upgrade to grease fitting for later service looks the way to go.
2Back to top Go down   1985 K100 drive shaft/U-Joint Empty Re: 1985 K100 drive shaft/U-Joint Thu Jun 28, 2012 2:16 pm
cruise_carter
cruise_carter
http://www.brunos.us/
lots of folks use this guy, excellent service according to my buddy whose family all rides old k bikes and have had work done
Currently on the hunt for another old K bike (K100RS would be perfect)
2004 R1200CLC (gone recently......those evo brakes are brutal)
1985 K100RT, lots of km but lots of life left (gone)
2002 HD Electra Glide Classic (gone)
1987 K100RS (gone)
2002 HD Road Glide (gone)
2000 R1100R (gone)
lots more in the past........
3Back to top Go down   1985 K100 drive shaft/U-Joint Empty Re: 1985 K100 drive shaft/U-Joint Thu Jun 28, 2012 9:20 pm
Bruno has a very good reputation, apparently it cost a bit to get it in and out of Canada with customs etc but is still worthwhile.
4Back to top Go down   1985 K100 drive shaft/U-Joint Empty bearing Thu Jun 28, 2012 9:30 pm
rwiley111
rwiley111
I know about Bruno service, what I was looking for was the bearing/U-Joint replacement number so I can do it myself.
5Back to top Go down   1985 K100 drive shaft/U-Joint Empty Re: 1985 K100 drive shaft/U-Joint Thu Jun 28, 2012 9:45 pm
Don`t know if the 1200 the would fit................
6Back to top Go down   1985 K100 drive shaft/U-Joint Empty Re: 1985 K100 drive shaft/U-Joint Thu Jun 28, 2012 9:56 pm
It should fit as Bruce does an exchange drive shaft as well and it says K2/K4.
Munich in Perth west Oz are good to deal with but a bit expensive at times.
7Back to top Go down   1985 K100 drive shaft/U-Joint Empty Re: 1985 K100 drive shaft/U-Joint Thu Jun 28, 2012 10:55 pm
cruise_carter
cruise_carter
rwiley111 wrote:I know about Bruno service, what I was looking for was the bearing/U-Joint replacement number so I can do it myself.
sorry, missed this in your original post, thought you were looking for a driveshaft.....
maybe Bruno might be nice enough to give you the numbers if you contacted him
1987 K100RS (gone)
2000 R1100R (gone)
8Back to top Go down   1985 K100 drive shaft/U-Joint Empty Thank You Fri Jun 29, 2012 2:34 pm
rwiley111
rwiley111
Inge K., Thank you for the information and Munich Motorcycles in Perth carries the bearing. The part number for a replacement bearing or upgrade must be like a International Guarded Secret, should be able to have the number and go to a bearing house and pick it up, when I take mine apart I will measure and find the information and post them.
