1 Help with electrical issue(s) - Sacramento CA Sun Aug 04, 2019 1:25 pm
Javi54
Hello everyone - I have a 1993 K1100LT. The bike has some sort of short (+ other e-issue) that I cannot find. It started with the headlights flickering once in a while while switching from high to low beam. One day I pull into my driveway, come to a stop and turn the handle bar slightly and it died. After that, the bike started just fine and I had it parked in my shop for all winter. This spring I wanted to get it out; the bike started right up but had a gas leak in one of the fuel lines coming out of the fuel tank. I replace the fuel lines, and since I was a it, I also replace a faulty wire harness for the windshield and replaced the high/low bean switch assembly with a used part. Before putting all back together I tried starting the bike; the first thing I notice the headlights would not work; the starter is not turning now either (just makes a one click sound). All fuses are fine and the grounds seem to be fine; the battery is on a battery tender so I am assuming it is good - I will check it though; anyway I am okay mechanic (i.e. I've never had to take a car or bike to a shop for repair) but not for electrical. Can someone help me trouble shoot this? If you are close to Sacramento, stop by to help and I'll be willing to provide bbq, beer, and if required, $s.
Thanks, Jav
Thanks, Jav
1993 K1100LT
Galt, California
