1 Engine oil clarification Wed Jun 05, 2019 12:14 pm
Heresy23
ok so I have a question that has obvious answers but really the combined experience of yinz will make it a bit clearer
What do you think is the best oil level to have and do you notice a performance difference with that level? Mine is at the top of the sight glass (not overfilled) but in my experience it’s better to have it in the middle,I think it helps with engine vibration...(on my other bikes)
So I hav a leaking engine output shaft and I was reading that some people feel if you keep the oil at about the middle of the sight glass it leaks less?
I was thinking of draining some oil so it’s right in the middle of the sight glass, and as far as the leak in concerned, I always carry a quart of oil “just in case”...my original thinking about keeping the oil at max was so that I always know my oil level isn’t getting low(for a while) becuase of the leak...it’s a small leak and it’s been 3 weeks since I changed oil and the level haven’t moved....
Do you think keeping the oil right about in the middle of the glass makes her run better then “completely full”?
Thanks !
Thanks !
