1 Cold start knocking and oil dripping from weep hole Sat May 25, 2019 12:15 am
Heresy23
Hi, so just got a 85 k100 and I’ve been reading around about the common “cold knocking engine sound” well, over the course of 2mweeks my idle has been terribly low on cold start and has got to the point I had to at least turn the idle screw to raise it to around 1.1k (did this tonight) so I don’t have to drive with the choke on....but before tonight , once the engine was warm I could leave choke off with almost no stall worry...
So far I’ve :
Changed the fuel filter,
Oil ,
Gear and final drive oil,
Adjusted free play in throttle ,
Cleaned the air filter,.
The engine knocking is so bad until I just jump on and drive and once warmed it runs great knocking is gone.
But...tonight (before raising idle speed) I had to give it gas to keep it running on a cold start......jumped on and it had tpower loss and some sputtering until I got it very warmed up (riding around)then all was good ...but with the choke not on it would stall (sometimes )at red lights ....point being the idle issue did get better but is getting worse again...
Oh and I started getting oil (not gear oil)leaking from the weep hole a week ago and it’s getting worst but not too bad..this bike is my only transportation and I just need it to last till winter when I can change seals and do a spline lube...oh and no slipping on clutch so I’m assuming oil isn’t getting to the clutch ...yet....so my questions are .....
1:Is that knocking really pretty “normal “ for k100’s and is that knocking even worse becuase my idle is so low at startup?
2: with the weep hole telling me about the seal needing changed do you think I could hold it off for about 6 months if it doesn’t make my clutch slip?
3: I know I gotta check the plugs(they were changed 2k miles ago and roughly a year ago by previous owner )but what else could be making my idle so bad(which makes that banging I hate worse on cold startup)?
I know this is very general...I will get more specific later ....just need some guidance , I’m very mechanically inclined but this is my first bmw and my first bike with 71k miles already on it...
Thank you
So far I’ve :
Oil ,
Thank you
