Thanks Charlie and Rick I'll keep that in mind.
Anyone ever had any abnormal engine pressure issues with a K ?
If all parts are in there normally, I need to find the answer to what causes this condition.
Only then will I stop the problem from reoccurring.
Has anyone ever change out the breather system? As one possibility, could there be too much internal engine pressure?
I don't know if that is the case, however, I have taken the oil fill cap off and at idle there is pressure exiting the cap hole but it doesn't feel excessive (I don't really know what excessive is though). At 3,000rpm, there isn't any more pressure but it feels like a smoother blowing out rather than a "burlbing" - but again, it doesn't feel excessive enough to push out a rear main seal to me. ???
Another thing - I have read that the rear main needs to be protruding just a bit.
I read that BMW had an internal service bulletin back in 1997 revising rear seal replacement but I don't know how critical it is.
If the seal was placed in there flush each time by mistake, would it lead to a R main seal that is soon to leak???
The "mechanic" that replaced everything last year said that he could not find a leak...but the clutch was oiled and fluid was exiting the weep hole (not in great quantities).
I should have first required him to find the source of leakage and second to remedy the problem. I thought I hired a mechanic but instead hired a parts installer.
As of now, I have a motorcycle that is not going anywhere for the second summer in a row.
Any thoughts and suggestions on a possible solution to the puzzle are really appreciated.
