Gr-Racing
Gr-Racing
hello im in the process of wiring in the aftermarket controls on my K, I have the wiring diagram and have done some searching and Im pretty sure I got the right side control correct.
my left side control not so much and hence im here asking from a bit of info from the gurus.
I know I have to re wire the turn signals and install a aftermarket relay for them im ok on that
my problem is how to wire the setup I want correct on the left control I want  headlight on/off , Headlight High beam , turn signal
im almost there but want to double check before I blow up the garage .
sorry for my crappy diagram
installing aftermarket controls 3 switch i need  help plz E08771-EB-8882-4644-A6-F9-203-C9-AD39379
Gr-Racing
Gr-Racing
Thanks for the reply, i seen it and pull some info from it but the wire color are a bit hard to understand
Gr-Racing
Gr-Racing
Sorry i just saw that my dislexia strikes again for the start is black/green and black/yellow
Left:
Pin #ColorDesc.
1WhiteHigh beam, indicator in cluster
2Open
3Blue/BrownLeft turn signal - ground to flasher relay Pin 8
4YellowLow beam
5Open
6BrownGround in
7White/YellowHeadlight power in from right combo switch
8Green/BlueLoad shed relay, F7, headlight power in to right combo switch
9Brown/YellowHorn relay - ground
Right:
Pin #ColorDesc.
1aBrown/WhiteTurn signal cancel - ground to flasher relay
1Black/YellowPower to starter from start button from Pin 6
2Green/YellowPower to lots of things (to Pin 9 via kill switch)
3Gray/BlueShorted to Pin 4 with gray wire (parking lights)
4White/YellowHeadlight power to left combo switch
5Blue/YellowRight turn signal (grounds)
6Black/GreenPower to start button from clutch switch and gear indicator
7Green/BlueShorted to Pin 4 with gray wire (power in for parking/head lights)
8BrownGround in
9GreenLoad shed relay, ignition switch
Gr-Racing
Gr-Racing
thanks for the help guys, got the right side working fine still working on the left control
