1 K1100LT Coolant/oil Pump Thu Mar 21, 2019 2:42 pm
brickrider2
I'm back to dealing with the #!*%+* coolant/oil pump. I followed the instructions for installing the rebuild kit to the letter - as far as I know - yet there is evidence of a coolant leak. I'm at a loss to understand where the mistake was made, but I'll give it another try. I can apparently buy only the ceramic seal from the popular English parts supplier. Since the other installed bits and bobs in the rebuild kit are virtually new, just replacing the ceramic seal should be sufficient, correct?
The weeping from the pump is slight, so I'll just pack a little coolant in the pannier during my Southwest tour next month. Upon my return I'll pull the pump apart again gurrrrrr
1996 K1100LT
