1 K100 water/oil pump housing problem Wed Feb 13, 2019 4:33 pm
PiotrK100
I have a problem with water/oil pump. My K100 is from 1983 so the old shape of gear was with the nut on the shaft instead o bolt. So what was precictable it was corroded and I broke it. I bought another pump but things inside looks different like number of tooths and also slightly different housing shape.The question is f both pumps on the pics are interchangable??? Also I have aproblem with removing the shaft (in "new" pump) from water sealant and housing, I punch with hammer with force but affraid to use bigger force not to brake something. Is that possible the shaft seizure inside sealant or rosted? If that is a matter of the higher accesive force..no problem, just wanted to be sure.
