jdpanero
jdpanero
1.  I'm putting in my oil pump seal and there's massive free-play inside the housing.  I contacted the parts store because I'm guessing they sent the wrong size.  Thoughts?
2.  Is my oil pump shaft good to use again?  There's a hairline groove and it's perfect otherwise.
Pictures?
Moved thread from 'How To - Article telling others how to perform a task', to 'Troubleshooting - Engine...'
"Politics is the entertainment division of the military industrial complex."
- Frank Zappa
jdpanero wrote:1.  I'm putting in my oil pump seal and there's massive free-play inside the housing.  I contacted the parts store because I'm guessing they sent the wrong size.  Thoughts?
Year and model? It's a good idea to go to Profile at the the top of this page, and under Signature, place the bike's info there so others are aware of which K bike year/model & as often helps, the last 7 digits of the VIN you're attempting to work on.
- Frank Zappa
jdpanero
jdpanero
Added.  Thanks for the tip.
jdpanero
jdpanero
Oil/Water pump repair issues - 1988 K100 Img_0313
Without seal.
Dai wrote:Pictures?
Oil/Water pump repair issues - 1988 K100 Img_0316
With loose seal
Motobins says the OD of the seal should be 25mm, which it is.  I'm confused.  The seal has 2-3mm of free play in the housing.
jdpanero wrote:
Two Wheels Better wrote:Year and model? It's a good idea to go to Profile at the the top of this page, and under Signature, place the bike's info there so others are aware of which K bike year/model & as often helps, the last 7 digits of the VIN you're attempting to work on.
You must not have pressed Save, or put it in the wrong place, since it should be visible with every post you make. See mine below, and other member's.
Don't just let it default under Profile and then Information, where it's a blue panel, but click on the Signature tab and a white panel opens up for the information you wish to add.
- Frank Zappa
jdpanero
jdpanero
One more try.
1988 K100LT Cafe Racer VIN 0180895
Success! cheers
Now down to the issue at hand...
There are pump variations and the old stuff may not be available any longer which may mean you purchase a different impeller, or not. It's been yonks since I have dug into those variations, things like shaft OD diametre,, but there are others here recently and I suggest a dive into the forum's search engine with simple titles like "water pump seal" or "oil pump shaft".
- Frank Zappa
Watch kennyraceboy, jdpanero. He might explain what could be interfering with your pump rehabilitation.
Well done. That vid is prolly the easiest and simplest explanation I've seen for a thorough going over of the pump assembly of an early K.
- Frank Zappa
jdpanero
jdpanero
I got it figured out.  When I was removing the old oil seal it split into hundreds of pieces and I didn't realize the metal ring of the seal was still in the housing.  On to the next steps.  Thanks.
Ah. That's happened to many of us.
