1Back to top Go down   K100 water/oil pump housing problem Empty K100 water/oil pump housing problem Wed Feb 13, 2019 4:33 pm
PiotrK100
PiotrK100
I have a problem with water/oil pump. My K100 is from 1983 so the old shape of gear was with the nut on the shaft instead o bolt. So what was precictable it was corroded and I broke it. I bought another pump but things inside looks different like number of tooths and also slightly different housing shape.The question is f both pumps on the pics are interchangable??? Also I have aproblem with removing the shaft (in "new" pump) from water sealant and housing, I punch with hammer with force but affraid to use bigger force not to brake something. Is that possible the shaft seizure inside sealant or rosted? If that is a matter of the higher accesive force..no problem, just wanted to be sure.K100 water/oil pump housing problem 20190210
http://www.xenum.pl
Avenger GT
Avenger GT
That's a K1100 pump, it will fit and work perfectly on a K100. I have one on my RT for about 10 years.
PiotrK100
PiotrK100
Thanks for info. What about water sealant, are they similar in late K100 and K1100? Also I do not know why I can not pull out the gear, even when hit with the hammer. Is seizured or I did not unscrew something???
http://www.xenum.pl
Avenger GT
Avenger GT
PiotrK100 wrote:Thanks for info. What about water sealant, are they similar in late K100 and K1100? Also I do not know why I can not pull out the gear, even when hit with the hammer. Is seizured or I did not unscrew something???
Does it rotate? If so it's not seized.
PiotrK100
PiotrK100
It is rotate, but can not pull out!!!! Must be the reason of some kind and I do not know what. MAybe there is something in that housing that must be unscrewed???
http://www.xenum.pl
brickrider2
brickrider2
I recently rebuilt the water/oil pump on my K1100LT.  The shaft came out without much effort.  I think there must be rust/corrosion that is causing your problem.  I would just "get a bigger hammer" and drive it out.
1996 K1100LT
PiotrK100 wrote:It is rotate, but can not pull out!!!! Must be the reason of some kind and I do not know what. MAybe there is something in that housing that must be unscrewed???
Nothing in the housing to hold the shaft except the old seal. I have ( in the past) put the pump in a big vice, with some wood to save the mating surface of the housing and enough space to squeeze the shaft out a little.
If you don't have a big vice use some timber blocks on the face and a piece to hit on the back. once dislodged it should come easily.
good luck
K100 water/oil pump housing problem Ir-log1188....May contain nuts!K100 water/oil pump housing problem Ir-log11
K75RTP - 1994
could it be, that he has the new ceramic type water seal already installed ?
advice would be not to try to change it ...as it must be destroyed to be removed
just a heads up
