1 Bad misfire Mon Mar 18, 2019 5:04 am
ajsm18
Hi,
I haven't used my bike much this winter but, when I have everything seems to have been fine. I replaced the battery a few weeks ago as it has struggled to start at times and failed completely once when I made a short stop.
The new battery has transformed the starting. This morning, though, it has developed a serious misfire. The symptoms are that it just seems to keep cutting out and then pick up again. This seems to be at all times - when accelerating, on a steady throttle and when slowing down.
It started OK and idled on the choke when I left home but after a mile or so started to misbehave.
The first half of my 20 mile commute is at about 40 mph and the second half at motorway speeds. As far as I could tell, it was bad all the way and when idling as I parked at work.
I'll go out and check it will start when it has cooled down and that nothing has come loose under the seat but any thoughts?
I have to say that, apart from oil, battery, brake and tyre changes, it is pretty neglected so I guess it could be the air filter is clogged and I've never attempted to touch the fuel system but I thought I'd ask for any pointers as I don't really want to strip it down to fix!
Mark
Mark
