1Back to top Go down   Misfire issues  Empty Misfire issues Sun Aug 20, 2023 12:20 am
wizz1234
wizz1234
Did 100 miles bike ran really well apart from speedo playing up 7 days ago. Over the next few 7 days I started the bike up few times while I was while I was diagnosing the Speedo issue. Went to ride it today and the bike is misfiring and lakes power. If I hold it at say 3000 revs when stationary the revs start going up and down. Any suggestions please thanks. When riding the bike if I tried to accelerate the bike goes into kangaroo mode
2Back to top Go down   Misfire issues  Empty Re: Misfire issues Sun Aug 20, 2023 12:27 am
Have you replaced the fuel filter and also it is possible the ignition switch needs cleaning.
3Back to top Go down   Misfire issues  Empty Re: Misfire issues Sun Aug 20, 2023 8:02 am
wizz1234
wizz1234
No I haven’t done anything yet where is the fuel filter?
4Back to top Go down   Misfire issues  Empty Re: Misfire issues Sun Aug 20, 2023 8:18 am
Inside the tank, do a search of the forum and you will find many threads about changing the fuel filter.
5Back to top Go down   Misfire issues  Empty Re: Misfire issues Sun Aug 20, 2023 5:08 pm
wizz1234
wizz1234
I have a spark on all 4 plugs and I have reseat the ecu is there a way of checking to see if there is a fuel blockage
6Back to top Go down   Misfire issues  Empty Re: Misfire issues Mon Aug 21, 2023 12:23 am
Click on the PORTAL tab and then Tech Page below the blue/yellow moto and then agree then the very first item is how to replace the fuel filter.
When you get a new to you K assume that no maintenance has ever been done.  Replace all fluids and filters as a minimum.
7Back to top Go down   Misfire issues  Empty Re: Misfire issues Mon Aug 21, 2023 3:54 pm
wizz1234
wizz1234
I have ordered a fuel filter
