1Back to top Go down   Naughty K 100 rs 1984 model, Empty Naughty K 100 rs 1984 model, Sat Feb 16, 2019 1:34 pm
moriarti
moriarti
Hi everyone many brains needed for this one.OK bike runs a dream until you start to ride harder eg, 80 mph plus,engine nice and warm .THEN the damn thing cuts out and re starts in a second not nice,this will continue every few minutes until i stop and wait for 20 mins or so, set off again ride easy all ok wind it up  and bother it starts again .NO lights come on when this happens,if i pull over and stop the bike runs perfectly . affraid affraid what am i to do ,help and good humour most welcome lol!
2Back to top Go down   Naughty K 100 rs 1984 model, Empty Cutting out Sat Feb 16, 2019 2:28 pm
daveyson
daveyson
Hall sensors?
 ~120,000 km
3Back to top Go down   Naughty K 100 rs 1984 model, Empty Re: Naughty K 100 rs 1984 model, Sat Feb 16, 2019 3:40 pm
moriarti
moriarti
daveyson wrote:Hall sensors?
My thinking too, study  Iwas hoping for  "its a loose fuse number 69 in the box"  Razz Dont like putting the hand in pocket syndrome,Ill give Motorworks a ring and stand the pain if i must.Thanks for your opinion,as we say up here 2 heads are better than 1 even if their sheep heads he he . Naughty K 100 rs 1984 model, 161205
4Back to top Go down   Naughty K 100 rs 1984 model, Empty Cuttig out Sat Feb 16, 2019 3:44 pm
daveyson
daveyson
There's probably a way to test it before ordering a new one.
 ~120,000 km
5Back to top Go down   Naughty K 100 rs 1984 model, Empty Cutting out Sat Feb 16, 2019 3:59 pm
daveyson
daveyson
On some cars you could spray them with water and it would suddenly be problem solved, but your case is so short timed it might make no difference.
 ~120,000 km
6Back to top Go down   Naughty K 100 rs 1984 model, Empty Re: Naughty K 100 rs 1984 model, Sat Feb 16, 2019 4:12 pm
Typically a bike dieing when it gets warmed up is a sign of the HES going bad.
Take some  cool water with you and throw that on the HES cover to see if that makes it start again.
Another thing you can do to test is remove the HES cover (try to do it carefully so as not to tear the gasket) then use a heat gun on the HES to see if it will cause the bike to die.
Another possible issue is the gas tank connector being flaky - causing the fuel pump to run intermittently.
Or a flaky ignition switch.
7Back to top Go down   Naughty K 100 rs 1984 model, Empty Re: Naughty K 100 rs 1984 model, Sat Feb 16, 2019 5:54 pm
moriarti
moriarti
duck wrote:Typically a bike dieing when it gets warmed up is a sign of the HES going bad.
thanks duck ,i can run the bike on the stand for over an hour rad fan running flat out ,and the engine NEVER misses a beat,only fails over 3000 rpm when being ridden,cuts out and back in in a second stop at rd side and rev 5/6000 no problem  Embarassed Embarassed ,set off again ride hard problem back again  Evil or Very Mad I will however try the hot air/dryer idea,Wish me luck as i try to protect my pocket lol!
8Back to top Go down   Naughty K 100 rs 1984 model, Empty Naughty Sat Feb 16, 2019 6:07 pm
daveyson
daveyson
Temperature sensor?
 ~120,000 km
9Back to top Go down   Naughty K 100 rs 1984 model, Empty Octane Sat Feb 16, 2019 6:18 pm
daveyson
daveyson
I'd avoid running it for an hour on the stand,  it wasn't designed for that.
 ~120,000 km
10Back to top Go down   Naughty K 100 rs 1984 model, Empty Re: Naughty K 100 rs 1984 model, Sat Feb 16, 2019 6:58 pm
daveyson wrote:I'd avoid running it for an hour on the stand,  it wasn't designed for that.
Yes. The owner's manual recommends starting it and riding off.  Lots of idling also tends to foul spark plugs, especially on K75s.
11Back to top Go down   Naughty K 100 rs 1984 model, Empty Re: Naughty K 100 rs 1984 model, Sat Feb 16, 2019 8:07 pm
moriarti
moriarti
True,now here is the thing in heavy traffic on a hot day high temp light comes on until out of traffic ,AND still no fault,Fault only o cures at speed over 70/80 mph plus,I haven't had this problem  myself,my friend Jim has the problem when he rides the bike,over  the last few months i noticed today when he got back that he uses the kill switch to stop the engine .Something i never do,when asked his reply was ,i always use it.Now bearing in mind the age of the bike and in over 20 the kill switch has not been used,couldit be a simple case of sticking switch ,
with a bit of vibration at high speed,We live in hope of easy fix Shocked
12Back to top Go down   Naughty K 100 rs 1984 model, Empty Re: Naughty K 100 rs 1984 model, Sat Feb 16, 2019 9:11 pm
moriarti wrote:. . . i can run the bike on the stand for over an hour rad fan running flat out ,and the engine NEVER misses a beat . . . here is the thing in heavy traffic on a hot day high temp light comes on until out of traffic ,AND still no fault,
While the engine idles for an hour with a coolant system in good condition, my experience indicates that the fan should run intermittently, not flat out.
Consider reviewing the condition of your moto's radiator, pressure cap, coolant, coolant temperature sensor, temperature sensing switch, fan and fan wiring. On a moto with a cooling system in good condition, the high temp light should not be activated in heavy traffic on a hot day; instead, the fan should run more often and for longer intervals keeping the engine at appropriate operating temperature.
Intermittent cut-out can be a symptom of defective electrical connections other than Hall sensors. Inspecting and testing Hall sensors is good practice when a fully warmed engine cuts out and can be restarted after cool-down but your moto seems to have problems with its cooling system beyond their condition.
13Back to top Go down   Naughty K 100 rs 1984 model, Empty Naughty Sat Feb 16, 2019 9:32 pm
daveyson
daveyson
+1 what Laitch says
Also,  it doesn't cut out at high temperatures if your riding but does for the other guy.  So it's not a temperature related problem so much.  Probably the kill switch wants a good clean.
 ~120,000 km
14Back to top Go down   Naughty K 100 rs 1984 model, Empty Naughty Sun Feb 17, 2019 1:39 am
daveyson
daveyson
Ask him for more detail so you can repeat it.
Could it be he is not used to the feeling of fuel cutting out on deceleration, then instinctively he accelerates to compensate? That might explain the one second duration. Throttle position sensor adjusted?
 ~120,000 km
15Back to top Go down   Naughty K 100 rs 1984 model, Empty Re: Naughty K 100 rs 1984 model, Sun Feb 17, 2019 1:50 am
First place I would be looking would be the connection to the tank then the ignition switch and I would give odds on that you find the fault.
16Back to top Go down   Naughty K 100 rs 1984 model, Empty Re: Naughty K 100 rs 1984 model, Sun Feb 17, 2019 4:06 am
Suzi Q
Suzi Q
From the symptoms it suggests some consistency between high revs/cutting out and low revs/ok. If you are certain that is what is happening, and the consistency is strong, then I'd add a suggestion that you could have a blocked fuel filter. Happened to me.
I wouldn't have described it as fully 'cutting out' though; more like a horrible rev limiter - coughing and missing and dying and not revving past four or five thousand or so. Ran fine at lower revs.
BTW whereabouts in West Yorksher are you - I am a spit from M1 J36 and I have a spare Hall sensor, available on Sundays too...!
17Back to top Go down   Naughty K 100 rs 1984 model, Empty Re: Naughty K 100 rs 1984 model, Sun Feb 17, 2019 2:15 pm
My 84 did that sometimes.....electrical plug on front left of the gas tank was an issue, adjusted the pins.
Then it started happening again.....lose plug on the injection unit under the seat.
Hall sensors fail don't normally give an instant restart.
Temp sensor on 2v does not have a cut out function, it only has a start inhibit function if over heated. If your fan is working ok it should kick in so the temp light does not come on.
18Back to top Go down   Naughty K 100 rs 1984 model, Empty Re: Naughty K 100 rs 1984 model, Sun Feb 17, 2019 4:35 pm
moriarti
moriarti
chris846 wrote:From the symptoms it suggests some consistency between high revs/cutting out and low revs/ok. If you are certain that is what is happening, and the consistency is strong, then I'd add a suggestion that you could have a blocked fuel filter. Happened to me.
Moriarti wrote:
mANY THANKS to all for you advice and ideas ,im making a list and will post after iv finished the jobs,TO chris846 thanks for the offer im in Brighouse about 45 minutes away from your good self,i will contact you should i need to loan the hall sensor study lol!
19Back to top Go down   Naughty K 100 rs 1984 model, Empty JOBS DONE Tue Mar 19, 2019 8:28 am
moriarti
moriarti
HI to all,First, welcome to our new members, Very Happy i am having trouble with the site,NOT SECURE WARNING stopping me logging in  affraid study .Now back to the K ,Hall sensors,tested out ok both hot/cold (hairdryer is good for this test)
ignition switch ok .All grounds test ok ,Only fault found is Light switch off/side/ head faulty,starter button/kill switch,some corrosion in  contact area plus heavy corrosion on square  connector to main harness .
S/H unit from MOTORWORKS £25,Cleaned all contacts.Just waiting for a nice day to ride out and test,
A local K specialist had a very easy FIX suggestion KEEP YOUR MATE OFF THE BIKE cheers study now why didn't you lot think of that one Razz
20Back to top Go down   Naughty K 100 rs 1984 model, Empty Re: Naughty K 100 rs 1984 model, Tue Mar 19, 2019 11:05 am
moriarti wrote:HI to all,First, welcome to our new members, Very Happy i am having trouble with the site,NOT SECURE WARNING stopping me logging in  affraid study .Now back to the K ,Hall sensors,tested out ok both hot/cold (hairdryer is good for this test)
He probably has early stages of K Pox.
21Back to top Go down   Naughty K 100 rs 1984 model, Empty Naughty k100 Wed Mar 20, 2019 3:16 am
daveyson
daveyson
If he is not aware that with your brick,  the fuel cuts out on deceleration, it's probably OK to let him ride it.  Some people are easily offended if baned from a bike, on the other hand, it's hard to break a brick.  bounce
 ~120,000 km
