1Back to top Go down   Electrical question Choke wire? Empty Electrical question Choke wire? Fri Feb 08, 2019 8:02 am
BronzeBeast
BronzeBeast
I was tracing the wire for the power outlet in the dash (removed gas tank)  Got to the bundle and while loosening it all up, i think I disconnected this wire.  (see two arrows)  The male side says 'choke' on the paper tab.
Did it unplug from the right arrow?  I didn't think I unplugged anything, but it seems this came apart, though I don't want to plug in if it's supposed to be disconnected.
Electrical question Choke wire? Choke_10
2Back to top Go down   Electrical question Choke wire? Empty Re: Electrical question Choke wire? Fri Feb 08, 2019 8:18 am
Woodie
Woodie
I don't have a specific answer to your question but if nothing has been changed from original then the colour of the wires and the specific sockets will tell you a great deal.  The wiring schematics in the tech pages have all the information you need to be able to identify everything.  BMW used a lot of different sockets and I would say that it would be hard to get the wrong things plugged in to each other.
Others will be along to give you a really specific answer though I'm sure.
Electrical question Choke wire? Logo2111
1985 K100RT  52667
1990 K75RT 6018570 (project)
3Back to top Go down   Electrical question Choke wire? Empty Re: Electrical question Choke wire? Fri Feb 08, 2019 8:29 am
What year is your bike?  If it's 91 or later BMW stopped installing theTB switch for the choke light in the instrument cluster so the wiring labeled choke is not connected to anything.
https://www.k100-forum.com/t13977-where-d-my-choke-light-go
4Back to top Go down   Electrical question Choke wire? Empty Re: Electrical question Choke wire? Fri Feb 08, 2019 8:33 am
It could also be clutch switch wire as its the same switch on 2v.
2V has 4 of them all same part, front brake, rear brake, choke, clutch
5Back to top Go down   Electrical question Choke wire? Empty Re: Electrical question Choke wire? Fri Feb 08, 2019 8:53 am
92KK 84WW Olaf wrote:It could also be clutch switch wire as its the same switch on 2v.
The switches are the same but the wires of the main harness that they connect to are not:
Choke switch: Violet/White and Brown
Clutch switch: Green/Black and Black/Green
6Back to top Go down   Electrical question Choke wire? Empty Re: Electrical question Choke wire? Fri Feb 08, 2019 10:48 am
It is a good idea to label the loom side of the plug connector.
7Back to top Go down   Electrical question Choke wire? Empty Re: Electrical question Choke wire? Fri Feb 08, 2019 10:55 am
92KK 84WW Olaf wrote:It is a good idea to label the loom side of the plug connector.
Not sure what years but on some US bikes BMW labeled them in English at the factory.
8Back to top Go down   Electrical question Choke wire? Empty Re: Electrical question Choke wire? Fri Feb 08, 2019 10:58 am
BB:
Your left arrow is the connector for the yellow choke indicator in the cluster.
If you follow the wiring from your right arrow it should end up at a switch on the rear of the throttle bodies if it's the choke indicator switch.
9Back to top Go down   Electrical question Choke wire? Empty Re: Electrical question Choke wire? Fri Feb 08, 2019 11:01 am
duck wrote:What year is your bike?  If it's 91 or later BMW stopped installing theTB switch for the choke light in the instrument cluster...
Duck, I went back and looked at his intro. It's an 87 K100. This is an example of members needing to put the bike's specifics in their signature line so we're not guessing when asked.
10Back to top Go down   Electrical question Choke wire? Empty Re: Electrical question Choke wire? Sat Feb 09, 2019 12:50 am
BronzeBeast
BronzeBeast
duck wrote:BB:
Thanks, perfect, I will trace it on Saturday.
11Back to top Go down   Electrical question Choke wire? Empty Re: Electrical question Choke wire? Sat Feb 09, 2019 12:51 am
BronzeBeast
BronzeBeast
Sorry, just joined last week, I'm new here.
I will take care of that now.
12Back to top Go down   Electrical question Choke wire? Empty Re: Electrical question Choke wire? Sat Feb 09, 2019 12:55 am
BronzeBeast
BronzeBeast
Signature Test
Edit:  Weird, other forums when you add/ change signature, it updates all posts.
1987 K100 LT - Bronze *for now
13Back to top Go down   Electrical question Choke wire? Empty Re: Electrical question Choke wire? Tue Feb 12, 2019 12:26 am
BronzeBeast
BronzeBeast
duck wrote:BB:
Thank you  everyone, now my choke indicator works!
Dash socket still isn't live, but tested wiring previous owner had (for his last decade charging) and it was live, so going  to use that.   Very Happy
