83-85 K100 fuel tank needed rather desperately Sun Jan 20, 2019 6:40 pm
![Dai](https://2img.net/u/4211/29/48/93/avatars/3608-23.jpg)
![Life time member Life time member](https://i.servimg.com/u/f80/11/71/56/74/bmw-5s10.gif)
I've already repaired two pinholes but now it's rubbed through the weld at the front. The PO was t-boned and the tank took a hefty knock that distorted it and pushed the weld up against the front right frame leg. I've patched it once (and glued a piece of rubber against the frame leg for further protection), but it's rubbed through again and although I patched it for a second time this weekend and took a BFM to the damage to try and relieve where it pushes against the frame, I don't think it's going to last. ebay at the moment only has £200 tanks from James Sherlock and I'm not sure I'm that desperate - yet.
