1Back to top Go down   K100 1983 noise from bellhousing Empty K100 1983 noise from bellhousing Sat Sep 15, 2018 3:47 pm
PiotrK100
PiotrK100
Hi
My friend is having a problem with badly noise from bellhousing side. When engine is cold is silence, but rising when engine warm up. That is no bearing in alternator, but for a first view sounds like that and it would be a piece a cacke. But that is something in bellhousing. I was looking for the answer but did not find exact answer. I pur carbon graphite additive to the engine and noise is overall less noticable.
I know I'll have to disasemble that part of engine but what to looking for?
I record a short movie with that noise: https://youtu.be/jfc2wCBPEYY
Desperately looking for answer.
http://www.xenum.pl
2Back to top Go down   K100 1983 noise from bellhousing Empty Re: K100 1983 noise from bellhousing Sat Sep 15, 2018 7:58 pm
Monkey nuts. Seriously. The noise got louder when you brought the alternator into view, so it's a good bet that one or more of the cush drive rubbers has collapsed.
https://www.motorworks.co.uk/vlive/Shop/Parts.php?T=5&NU=15&M=40&Ct=JA&SbCt=BA_15_40_JA_10&spPage=2
Part number: ELA64877
You need three of them.
3Back to top Go down   K100 1983 noise from bellhousing Empty Re: K100 1983 noise from bellhousing Sun Sep 16, 2018 6:49 am
PiotrK100
PiotrK100
Dai wrote:Monkey nuts. Seriously. The noise got louder when you brought the alternator into view, so it's a good bet that one or more of the cush drive rubbers has collapsed.
Hi Dai
Tha thanks for your post but when I do remove alternator the noise is same. No alternator no crush drive rubbers and same noise. Or I miss something??
http://www.xenum.pl
4Back to top Go down   K100 1983 noise from bellhousing Empty Re: K100 1983 noise from bellhousing Sun Sep 16, 2018 6:57 am
Loose rivets on the output shaft? Guys?
5Back to top Go down   K100 1983 noise from bellhousing Empty Re: K100 1983 noise from bellhousing Sun Sep 16, 2018 11:08 am
Two possible courses of action would be to wear earplugs or to inspect the output shaft components as illustrated and explained on the Tech page in the Portal at the link First renovation of a K100.
6Back to top Go down   K100 1983 noise from bellhousing Empty Re: K100 1983 noise from bellhousing Sun Sep 16, 2018 4:42 pm
PiotrK100
PiotrK100
Laitch wrote:Two possible courses of action would be to wear earplugs or to inspect the output shaft components as illustrated and explained on the Tech page in the Portal at the link First renovation of a K100.
Will you pls send me a direct link? I was looking for what you write but could't find. In the mean time found a lot of other post and information but no of them solve definitely the problem.
http://www.xenum.pl
7Back to top Go down   K100 1983 noise from bellhousing Empty Re: K100 1983 noise from bellhousing Sun Sep 16, 2018 6:23 pm
8Back to top Go down   K100 1983 noise from bellhousing Empty Now engine apart Sat Dec 22, 2018 10:51 am
PiotrK100
PiotrK100
K100 1983 noise from bellhousing 20181215
K100 1983 noise from bellhousing 20181213
K100 1983 noise from bellhousing 20181214
So, finnaly we got time to disassamble engine to looking for weird noise. I stuck on outputshaft because can not remove it from housing, that is very starnge but that "half" is keeping the bearing and make me impossible to take out whole shaft...did I miss something???? Please help, see pic.
Also I see a little starnge makks on bearing bed in engine housing, like bearing was sliping inside aluminium housing, or maybe that is just how it looks like. See pic.
And the last case is the starter clutch, three bolts which keeps clutch together were were very untight, like I use 15-20 Nm to unscrew them. Should be like that or they started to unscrewed themselves??
http://www.xenum.pl
9Back to top Go down   K100 1983 noise from bellhousing Empty Re: K100 1983 noise from bellhousing Sat Dec 22, 2018 10:56 am
nobbylon
nobbylon
gearbox knashing of teeth Smile dont worry, it will still run forever!
R1100GS Feb 1995
K100RS July 1989
R90s June 1975
R75/6 Feb 1976
F650GD May 2001
10Back to top Go down   K100 1983 noise from bellhousing Empty Output shaft Wed Jan 02, 2019 9:21 am
PiotrK100
PiotrK100
I have older model with 6 rivets on output shaft, rivets are not shot but I can feel a little loose like 1mm. Now, I have oportunity to buy second hand output shaft with 12 rivets. Will that fits without any problem? It is complete shaft with all on it, so if I do replace output shaft like that will be no problem???
http://www.xenum.pl
11Back to top Go down   K100 1983 noise from bellhousing Empty Re: K100 1983 noise from bellhousing Wed Jan 02, 2019 6:13 pm
Suzi Q
Suzi Q
The 12 rivet shaft is a straight swap, but you might find that it comes with the later type bearing - which was modified to prevent axial movement of the shaft. The outer race of the bearing has a flange, which replaced the circlip on the earlier models, and the engine casings were modified accordingly.
No worries, you can still use the earlier bearing, but I found it a benefit to loctite it into place, this prevented the slight axial movement which manifested itself as inconsistency in the clutch biting point.
12Back to top Go down   K100 1983 noise from bellhousing Empty Re: K100 1983 noise from bellhousing Thu Jan 03, 2019 4:41 am
PiotrK100
PiotrK100
chris846 wrote:The 12 rivet shaft is a straight swap, but you might find that it comes with the later type bearing - which was modified to prevent axial movement of the shaft. The outer race of the bearing has a flange, which replaced the circlip on the earlier models, and the engine casings were modified accordingly.
Thanks a lot, that was exactly information I was looking for.
http://www.xenum.pl
