1Back to top Go down   Grinding shims Empty Grinding shims Sun Sep 16, 2018 12:52 pm
BooG
BooG
I have seen some footage of a guy who grinds down the valve shim in question to the correct spec using a mounted wheel grinder. Anyone ever done that, and is it acceptable to do? Gonna do mine softly as I've got nearly 90,000 on the Odometer and they've never been touched. Some popping on decelaration has made me want to do them. Question
2Back to top Go down   Grinding shims Empty Re: Grinding shims Sun Sep 16, 2018 12:55 pm
nobbylon
nobbylon
Why bother? chances are you only need 1 or 2 and they are not expensive.
R1100GS Feb 1995
K100RS July 1989
R90s June 1975
R75/6 Feb 1976
F650GD May 2001
3Back to top Go down   Grinding shims Empty Re: Grinding shims Sun Sep 16, 2018 1:51 pm
BooG
BooG
Its more to do with the waiting and downtime. If I have to remove the cover, make the measurements, and then put it all back together again in order to use it, (Everyday user), it'd be more convenient to take out a shim, grind it to the right spec, and replace it there and then. I agree that they may need minimum attention. The bike starts very eagerly, and the only indication is an increase in popping when slowing down from speed: as I change down.
4Back to top Go down   Grinding shims Empty Re: Grinding shims Sun Sep 16, 2018 1:57 pm
Some workshops will exchange them for a small fee. And some of the Japanese bikes have the same size shims, and they might also do an exchange.
5Back to top Go down   Grinding shims Empty Re: Grinding shims Sun Sep 16, 2018 2:06 pm
BooG
BooG
Cool....I'll investigate that.
6Back to top Go down   Grinding shims Empty Re: Grinding shims Sun Sep 16, 2018 2:22 pm
Boo somebody will probably chime in with the appropriate model Japanese bike shims. There was a discussion very recently.
7Back to top Go down   Grinding shims Empty Re: Grinding shims Sun Sep 16, 2018 2:28 pm
Do not use shims with chamfered edges. Seehttps://www.k100-forum.com/t13536-valve-clearance
8Back to top Go down   Grinding shims Empty Re: Grinding shims Sun Sep 16, 2018 4:42 pm
BooG wrote:I have seen some footage of a guy who grinds down the valve shim in question to the correct spec using a mounted wheel grinder. Anyone ever done that, and is it acceptable to do? Gonna do mine softly as I've got nearly 90,000 on the Odometer and they've never been touched. Some popping on decelaration has made me want to do them. Question
If you grind the shims you run a good chance of them cracking and if you have ever seen a cylinder head after that has happened then you will know for sure why and what happens. The head wont even get good scrap value because of the fine particles of embedded steel.
9Back to top Go down   Grinding shims Empty Re: Grinding shims Sun Sep 16, 2018 8:50 pm
nobbylon
nobbylon
It takes 15 mins to pull the cover and another 15-20 to take measurments and work out what shims are necessary. Replace cover, order shims and then pull it again and sort properly. The bike is worth a proper job, don’t botch it.
R1100GS Feb 1995
K100RS July 1989
R90s June 1975
R75/6 Feb 1976
F650GD May 2001
10Back to top Go down   Grinding shims Empty Re: Grinding shims Mon Sep 17, 2018 11:31 am
brickrider2
brickrider2
"Why bother? chances are you only need 1 or 2 and they are not expensive."
Out of curiosity I checked with an on-line BMW parts supplier.  If BMW valve shims are named "cam followers" then, at about US $35 each, they don't seem inexpensive to me. Valve shims for my Japanese or Italian bikes are about 1/3-1/4 of that price.
11Back to top Go down   Grinding shims Empty Re: Grinding shims Mon Sep 17, 2018 11:40 am
nobbylon
nobbylon
£8.60 each from motorworks for shims. I checked my silver K100 when I bought it and 2 were out. Swapping one for another solved one of them so I just needed one shim. Checked the blue RS this summer and all within specs. Chances are you would only need a few.
Measure the shims with a micrometer and not one of those digital verniers.
R1100GS Feb 1995
K100RS July 1989
R90s June 1975
R75/6 Feb 1976
F650GD May 2001
12Back to top Go down   Grinding shims Empty Re: Grinding shims Mon Sep 17, 2018 12:36 pm
brickrider2 wrote:Out of curiosity I checked with an on-line BMW parts supplier.  If BMW valve shims are named "cam followers" then, at about US $35 each, they don't seem inexpensive to me.
In MAX BMW's fiche, the 2V bucket is listed as cam follower @39.87USD. The 2V shim is listed as spacer @±13.71USD.
13Back to top Go down   Grinding shims Empty Re: Grinding shims Mon Nov 05, 2018 2:16 pm
BooG
BooG
Wemoto on the south coast: even cheaper!
