1 How To Wire Motogadget mLock RFID Keyless Ignition Wed Jan 24, 2018 7:22 pm
PNWK100
I had some issues sorting this out and finding info so I thought I'd share the solution. Here's how to wire up the Motogadget mLock (RFID keyless ignition) to the K100. I assume the K75 is similar if not the same.
The stock K100 wiring diagram for the ignition switch is shown top left.
To retain the stock connector you'll chop the pigtail off the ignition side (below) and solder / crimp in the wires from the mLock as shown above.
Hope this helps. It's a cool unit.
1985 BMW K100
