charlie99 wrote:would be good if dak provided a switch logic for the colours ?
Not dak (Or Dai even
) but here you go:
On Main Harness side you have
Red - Power IN - Constant Power From Fuse Panel
Green - Power OUT - to Kill/Run Switch
Grey - Power OUT to Park Lights
Grey/Blue - Power IN - Effectively from Load-Shed Relay for Lighting*
*The Grey/Blue circuit powers the Instrument Back Lighting, but note that this is not ORIGINATING from the Key-Switch, but an upstream circuit capability that creates that functionality and in this context is also used to provide the input pole for the park lights when the normal 'on' function of the switch is used.
When the 'Park' position of the switch is utilized it will light the park lights but NOT the instrument lights.
Normal 'On' Positions Couple Red to Green and Grey/Blue to Grey
'Park' Position couples Red to Grey
Few people will ever use the 'park' position of the Switch - if you don't need that feature, you can simple join the Grey/Blue and Grey together - the Grey/Blue is already 'switched' further upstream by the Red-Green pole of the switch, therefor it is no necessary to be switched again - the ONLY reason that additional switch is there is to provide the capability for the Park function. (It does not mean your Park Lights won't work in the 'On' position, only that you will no longer have functionality of the 'Park' position.)
If your new key-switch DOES have park position available and want to retain it, then check which wires are connected when that position is selected.
That leaves only the function for Red to Green to be connected when in On position
Again check your after-market switch to see which positions are connected together when key is on and connect accordingly.
Here is full functionality where the Park Light Operation of the switch is preserved
Here is much simpler version for those who do not want to have the Park Position Capability.
Note: my understanding/interpretation of MOT requirement in UK is that Capability for 'Parking' Lights is NOT actually required (there is Law about WHEN you would need to these IF you park
in certain locations, but NOT that the vehicle MUST be equipped - however the MOT requirement would be that IF the switch has the provision for the Park Position then it needs to be operational. i.e. if the switch does not have the capability then that will not constitute a failure.
Please check these regulations for yourself - that is my own interpretation when researching this previously (for use with my KeyLess Ignition system which does not have any Park capability
*important to understand - when I say Parking Lights I mean those lights that are on when the the key-switch is in the 'park' position and key may be removed; these same lights are also used for 'running' light function when the Key is in normal 'on' position.
With the simplified circuit above, those lights will remain functional in the 'running' mode (and only enabled by the key) but will no longer have capability in the 'park' mode.
