1 Unprovoked wobbling K100RS Mon Sep 03, 2018 6:16 pm
ERasberg
Dear community.
I had a bit of a scare on the highway yesterday and need some advise on how to start troubleshooting. Sorry for the rather wordy explanation. I hope you can bare with me ;
a) I was cruising at around 110km/h when I let the bike gently brake on the engine from about 120km/h to 90km/h.
b) At the same time i lifted the left hand from the handlebar, steering with just the right hand.
c) The bike suddenly started to progressively wobble on the tail until I, rather stunned, had to grab with two hands and engage the clutch to stop it.
I managed to reproduce this 2 times, only at high speeds.
I have been away for 4 weeks and it was the first ride coming home.
There is one characteristic that have changed (or been enhanced) :
There is now a distinct low frequency vibration coming from either the engine, the wheel or the shaft (I think). Almost like a tapping/clunking feeling or as if there were small perpendicular grooves in the road. This happens when I drive at around 100-120km/h or around 5000RPM. Distinct in 5th gear, also noticeable in 4th gear.
QUESTION :
1) What should I suspect first ? I have no idea how to troubleshoot this.
2) I worry about driving her now, should I park her until further notice ? Going to/from work today, no wobbling, but noticeable vibration.
3) I read in one post about an old Airhead that "made a rattling noise when decelerating and only in top gear. It went on like that for years (and 80,000 miles) until I had the money and time to repair it. The fifth gear cog was worn and 'wobbling' slightly on the output shaft. "
Could it be the same ? I thought the transmission/gearbox was a different design.
Info :
The tyres are 7 years old, a bit flat, but still plenty of groove. I re-inflated them to 2.3bar (front) / 2/5bar (rear).
The engine oil was changed 5W-40 this year.
The drive shaft oil has not been changed since purchase (supposedly) last year.
The rear suspension changed in 2011 by previous owner (10,000 km ago)
I have a RS handlebar (the short narrow one)
Your input and advise would be highly appreciated.
I bought the bike almost a year ago, use her often for work. I have put about 7000 km on her so far. I love the bike but being used to boxers I am still learning the driving characteristics and how to listen to the symptoms.
QUESTION :
Info :
Present
1988 K100 RS SE - VIN# 0146971K100RS - 105,000 km
1998 R1200C
1971 R75/5
Previous
1999 Virago XV125
1981 R65
